Question about HP DeskJet 990cxi InkJet Printer
HP 990cxi will not flip paper. The flipping attachment is installed,but it prints two sides on the same sid of the paper.
  • 805 Answers
First,
Before printing please check your page setup and also check your paper that means is must be similar.
2nd
please check your head alignment for it you can command for head cleaning.
Third,
please unload your cartridge and check your cartridge is it ok or any ink low. if dust over your cartridge then clean it.
4th,
uninstall your driver and restart your computer and then install your driver.
now try it
Posted on Apr 10, 2011
  • JAKEBIII Apr 11, 2011
    Thak you but I tried all that.
    However I also have a 970cxi, I checked the flipping mechanism and it is the same P/N so I tried it on the 990 and it works fine. So I have isolated the problem and will compare the two later to see if I can chase it down.
I want hp laserjet p2055d printer mirror printing solution
Mirror solution can be achieved by the position of inserted paper in the machine's tray.
Reference is printing in the latter head.
Feb 19, 2017 | HP Office Equipment & Supplies
My canon pixma 6150 does print on both sides of paper but the second/back side is upside down so I cannot make booklet
select long side flip rather than short side flip for an A4 booklet. An A5 booklet should be set for short side flip.
Feb 03, 2017 | Canon PIXMA Office Equipment & Supplies
HP7130 Incompatible settings
Please , you have to download the driver for win8 ,by samply serching on google.com for example "
HP Officejet 7130 All-In-One driver for win 8
Mar 21, 2013 | HP Officejet 7130 All-In-One InkJet...
How to print double sided
DOES THE PRINTER HAVE A DUPLEX MODULE ? Print out a configuration page and see if the duplexer appears under options. Good luck.
Jan 16, 2013 | Office Equipment & Supplies
We have a new hp lasterjet 4015n. It will print two sided, but it won't flip up the back side. I have my driver set to duplex print and flip up, but it won't flip up. Is there some setting on the...
I assume that you attached the two-sided printing accessory (duplexer) to your product:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=us&lc=en&dlc=en#N428
The duplexing has to be set in the printer's
Printing submenu
DUPLEX OFF/ON
This item appears only when an optional duplexer is installed. Set
the value to ON to print on both sides (duplex) or OFF to print on
one side (simplex) of a sheet of paper.
The default setting is OFF.
Print on both sides (Duplex) Click Print on both sides. If you will bind the document along
the top edge, click Flip pages up.
User manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 01, 2011 | HP LaserJet P4015N Printer
My duplex printer prints the second page(inside) of a half- fold card upside down. The printer wizard from orintmaster and printshop is designed for single- pass printers si that doesn't work... In fact,...
actually the gears in the printer are got worn out or some thing is blocking the gears so its not able to turn the paper internally to print on the right part of paper.and its printing upside down.remove the cartridge from the printer.and apply air blower in the inner area of printer.remove all the dust collected in the printer by blowing air everywhere in the printer.then check out if still the same problem the paper sliding gears needs to be replaced.you can get the gear assembly for local printer repair shop.they also help if replacing the gear assembly.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya
Oct 02, 2009 | Brother HL 5250DN Laser Printer
I have an HP PSC 1510. I got a new computer with vista and it no longer does 2 sided printing. It used to have a pop up that caused the printing to pause allowing me to flip the paper and would print the...
Wow! I have this same printer and I didn't even know it could do that. I don't know what's wrong with the machine, but to make 2-sided copies you can still just flip the paper, as long as you take the stack of blank paper out of the feed so it doesn't print your second side on a clean sheet.
Mar 24, 2009 | HP PSC 1510 All-In-One InkJet Printer
Unable to configure the HP C6380 for double-sided printing
Here is the step by step right from the user manual. also here is a direct link to the manual.
http://h10032.www1.hp.com/ctg/Manual/c01527492.pdf
Let me know how it works out for you.
Print on both sides of the page
You can print two-sided pages with the HP All-in-One manually. When printing two-sided
pages, make sure to use paper that is thick enough so that images do not show through
to the other side.
To print on both sides of the page
1.
Load paper into the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the product is the selected printer.
4. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Click the Features tab.
6. In the Paper saving options area, select Manual from the Two-sided printing dropdown
list.
Perform special print jobs 83
Print
7.
For binding, do one of the following:
• For binding on the top like a notebook or calendar, select the Flip Pages Up check
box.
This causes the odd and even pages of your document to print opposite of each
other top-to-bottom. This ensures that the top of the page is always at the top of
the sheet when you flip the pages up in your bound document.
• For binding on the side like a book or magazine, click to clear the Flip Pages
Up
check box.
other left-to-right. This ensures that the top of the page is always at the top of the
sheet when you turn the pages in your bound document.
3 5 1
8. Click OK, and then click Print or OK in the Print dialog box.
The product begins printing. Wait until all the odd-numbered pages are printed before
removing any of the printed pages from the output tray.
A dialog box displays instructions on the screen when it is time to process the second
side of your job.
9. Click Continue when done.
Nov 28, 2008 | HP Office Equipment & Supplies
I dont know how to make my printer print double sided
Go to File - print - properties. In properties there should be a tab for "printing shortcuts" the last option should be "print on both sides" It will prompt you to flip the paper when it's ready to print on the other side.
Oct 17, 2007 | HP Deskjet 5440 InkJet Photo Printer
HP DeskJet 990cxi InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
