Low voltge indicated - Computers & Internet
  • Juan Torres
    Juan Torres Apr 10, 2011
    could you provide a bit more detial?
  • 805 Answers
First,
check your charging cable that is okay. if charger okay then check your laptop battery is it capability to contain charge. if fault battery then change it. but remember before buy new battery please be insure the battery is same about your laptop brand and amphare and voltage. thanks
Posted on Apr 10, 2011
My FW780 will not make copies. Only white paper comes out after attempting to make a copy. No toner exhibited on the paper. I get no 'low toner' messages or warning lights on the control panel. What...
Check the developer motor maybe the developer is not functioning
or the primary and transfer corona needs cleaning as this cause the hi voltage leakage to ground
so hi voltge is produced results to no copy.
Jan 25, 2011 | Ricoh FW 780 Black and White Copier
Starter staring slow?
Check for low battery voltge and if ok you may need your starter removed and tested.
Nov 18, 2010 | 2001 Ford Focus
Our dishwasher does not drain and the red tap icon is now illuminated. Other things worked ok i.e. it cleaned the dishes ok but not it will not operate at all. It's about a year old. It is a Siemens...
The age is not a factor for this fault but I think that your drain pump is not working.
You will need to remove the drain hose and pull the pump off .
Use a voltge to check / remove clean dirt if action is low. If coils arre ok a ccleaning should solve.
however if the pump works fine on test then the controller unit is not outputing and could be faulty
Sep 11, 2010 | Siemens Dishwashers
Replaced battery. now malfunction indicator lamp
The light will stay on until about 20 starts. Once that 20th start is made, light should shut off. If not, it can be shut off by diagnostic scanner.
Nov 23, 2009 | 2000 Toyota Sienna
ALL Voltages (three wires) iones battery of Ton Tom one
Not sure why you would need to know this , red is live black is return circuit and the yellow is auxilliary and usually goes to charge input. as a live wire It is easier to cut and graft a new battery to the stubbs of wire than to solder new battery on. What you might really be needing is the polarity.. whether any charge pin is positive or negative if you are making a new internal charge point. Consult the back of the charger it usually states the polarity in a graphic.
Jul 23, 2009 | Tomtom One XL GPS Receiver
Compressor comes on, works for two minutes then the compressor shuts off whilke the fan continues. I recycle power on the unit and it continues top operate in this manner. I have left it off for a few days...
Your compressor has a safety built into it called a thermal protector. If you were to feel the compressor after one of these short cycles it would be extremely hot. Your compressor is malfunctioning, and it could be several things. I will list them in order of highest possibility;
Very low on refrgerant, Extremely dirty coil Fan motor failing, not enough electricity supplied to maintain compressor(should have its own circuit not shared) motor windings to compressor failing, restriction in refrigerant line, low voltge switching problem , wWithout a multimeter and gauges the two that you can ensure are clean coils and running it on its own circuit with proper sized wiring, you can clean the coil with a house hold sprayer and mild cleaner. Good luck
Jul 15, 2009 | Amcor Portable Air Conditioner...
I have a 1996 C180. The car is not holding charge even when driving. The battery and alternator are fine. The light for the battery is showing on the dash. I am completely stumped. Can anyone help me?...
The battery (or IGN) indicator on the dash, when lit, indicates that the alternator is not charging.
Check the battery terminals are not corroded, and the battery +12V and earth connections to the vehicle are in good order.
Check battery electrolyte lvel is ok.
Check the battery terminal voltage - it should be 13.8volts to 14.5 volts with the engine running. Switching on the headlights should not cause any reduction in that voltage while the engine is running.
The battery will not charge significantly unless the terminal voltge is in excess of 13.0V.
If all the above test ok, and the battery discharges between daily vehicle uses you may need a new battery.
Jun 17, 2009 | Mercedes-Benz C-Class Cars & Trucks
York central ac keeps blowing 3amp fuse on the circuit board when the compressor kicks in. thermostat changed with no help. what's next
sounds like you have short in the low voltge side of the electrical circuit. I would check the thermostat wires outside at the condenser. look for any bare or exposed wires from where the wire comes from the house to the condenser. the thermostat wire will be a brown wire that is run on the outside which sends a signal to the contactor to make the condenser work. common cause his rodents or happens when weed whacking around condenser. Hope this get you started.
Apr 26, 2009 | Heating & Cooling
TV Power
it is general problem in philips tv. it is due to low voltgs section of power supply might be defective
Sep 13, 2007 | Philips 32RF50S 32" TV
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
