Question about Garden
My mother bought a kit from someone at a yardsale. The instructions are included for the furniture. No instructions are included for constructing the dollhouse.
SOURCE: We need instructions for a Thermos pop up tent.
Is it the tent with the plastic staves? If so, just put them together and insert the rounded end into the equivalent hole on the bottom of the tent. Sit the tent upright with the doors open. Reach into the top of the tent and push/pull the chrome lever at the top until it locks into position. Sometimes you have to wiggle it around a little to get it to lock. When it does lock, you will know it because the tent is rigid. This is a great tent. We have used one for over 40 years! When you want to disassemble it, just pull down on the chrome lever at the top of the tent and reverse the procedure.
Posted on Jan 04, 2010
vetteman3002
  • 2299 Answers
SOURCE: I am looking for insturctions
They are buy it now on Ebay. They are $5.99. Here is the link to get to it.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=cambridge+CA750&_sacat=See-All-Categories
Posted on Oct 24, 2010
  • 32 Answers
SOURCE: we bought an grow colossal
Hi, cats92357,
Please allow me to give you some general instructions that might serve you well despite not having your instruction manual. I have had a lot of experience growing crystals, starting way back when I was a high school sophomore, and later after my college days when I was a chemical researcher often needing to purify chemical compounds. There were many different methods I used, but crystallization has always been one of my favorite ways, especially when my lab was in my childhood home's kitchen. Back then I followed detailed recipes (like you are probably expecting) from library books, but I always found them so tedious because of their many steps.
I think you might appreciate a simpler set of instructions that'll give you the general ideas behind successful crytal growing that you could apply to almost any inorganic chemicals ("salts") you have available in your chemistry kit or in your home.
The General Method (no details at first to give you just the overview - for details see the very bottom of this posted message.)
  1. Prepare a saturated solution of the chemical compound (the "solute") in water (the "solvent") at room temperature.
  2. Decant off most of the clear solution into another container, a process that allows you to separate the liquid from the excess solid on the bottom, so the liquid is particle-free.
  3. Add slightly more of the solid chemical to the saturated solution, keeping a record of how much you added.
  4. Heat the heterogeneous mixture (liquid + undissolved solid) to dissolve all of the solid.
  5. Filter out any undissolved solids particles to produce a perfectly clear solution still at the elevated temperature.
  6. Cover the top of the clear hot solution (loosely wrapped aluminum foil or paper towel) and let it cool slowly back down to room temperature. At this point you will have made what is called a supersaturated solution. That is what you need for successful crystal growing.
OK, now while the solution is cooling down, you can get different and interesting results depending on what you do next.
You could do one or more of the following steps:
  • Let the solution continue to cool down slowly undisturbed and let crystals begin to form spontaneously. This could take minutes, hours, or days, depending on a) the solute, b) the amount of chemical you added in step 2, and/or c) on how fast the solution cools. YOUR CRYSTALS WILL BE LARGER IF THEY FORM SLOWLY. THE FASTER THEY FORM, THE SMALLER THEY WILL BE. There's a lot of experimentation you could do to obtain optimum results! Just keep a record of how much chemical used, and every step of your procedure, so you can reproduce what you did, and so you can have a reference upon which to make small measurable changes in your scientific investigations.
  • Gently scratch the inside of the container (preferably made of glass) just below the surface of the room-temperature liquid with a glass stirring rod. Do this if you get impatient, since this technique often speeds up the crystallization process. The scratched surface, if you could see it under a high-powered microscope, would reveal broken silicon oxide bonds (from the molecular structure of glass) that would attract ions from your solute and initiate the crystallization process. You would see tiny crystals forming at the freshly scratced surface. They would become the nucleus or center for crystal growth. If you are using an glass container that has had a lot of use, there will already be enough scratched surfaces to do the job without your using a stirring rod. If you want more control on the rate of crystallization, I recommend that you use a brand new unused glass container.
  • Suspend your best tiny seed crystal (of the same substance) inside the cooling solution. This will cause most of the solute to grow only on your seed crystal and not so much on the glass surfaces. You can get really big crystals this way! The seed crytal would have to be large enough to allow tying with sewing thread. The seed crystal can be made by pouring a small volume of the still hot solution into a petri dish or some other small container like a saucer or dessert bowl or cup, etc, to have a shallow liquid level. Cover very loosely with paper towel and let the water evaporate. You want it to evaporate faster than your main solution above, but slow enough to allow crystals large enough to tie with thread. BE CAREFUL NOT TO SUSPEND THE SEED CRYSTAL IN THE SOLUTION WHILE IT IS STILL HOT ENOUGH TO DISSOLVE IT. Let the solution cool some first. Keep trying until your seed crystal does not dissolve; it's no big deal if it does, just tie another one and try again until you succeed. It will take some practice.
Salts that are often used for successful crystallization experiments are:
  • copper sulfate pentahydrate, CuSO4*5H2O. I'm using the asterisk to indicate that the water molecules are bonded to the metal. You can probably buy this salt at gardening shops, because it is used as a fungicide and also as a root killer to control tree root growth. It also is sometimes called "blue vitriol" or "bluestone." You probably guessed it, this hydrate is a beautiful blue crystalline solid.
  • aluminum potassium sulfate, KAl(SO4)2*12H2O, also known as potash alum (icolorless), and can be bought in a grocery store, because it is used in pickling.
  • chromium potassium sulfate, KCr(SO4)2*12H2O, also known as chrom alum (dark violet), and is used in tanning leather.
More details regarding the "General Method" described at the top:
  • Step 1 - Add enough chemical until the solid no longer dissolves but instead just falls to the bottom of the container. Add, stir, add, stir, etc, until you get a small layer of solid on the bottom of the container. This process allows you to form the needed saturated solution. It can hold only a certain amount of the chemical at a given temperature.
  • Step 2 - You could omit this decantation step if you were satisfied with the amount of solid on the bottom of the container.
  • Step 3 - You could also omit this step if you decided to use the solid already placed on the bottom of the container during step 1. However, using steps 2 and 3 as originally listed at the top might be better if you would like to be able to measure the amount of extra solid used.
  • Step 4 - This heating step necessary to convert the saturated solution into an unsaturated solution, that is a solution that has not reached its maximum level of dissolved solute. For most solutes, their ability to dissolve in water increases with temperature. The higher the temperature, the more salt can dissolve in a given volume of solvent.
  • Step 5 - This filtering step is needed to remove impurities, including dust, which could interfere with the crystallization process. You could use an oven mit to hold the container while you tilt it and pour the liquid into another (clean) container. Or, fold some paper towels together to use as an insulating strap to wrap around the neck of the container with both hands as you pour. DO THIS QUICKLY TO AVOID RAPID AND UNCONTROLLED COOLING. Too fast cooling will almost always result in the formation of small crystals.
  • Step 6 - Place the still hot container of clear solution on top of a dry insulated surface to avoid a rapid transfer of heat and uncontrolled cooling.
Posted on Jan 06, 2011
SOURCE: I need the instructions for
I need the instructions for the Duracraft Victorian Mansion Dollhouse Kit VM800 (it has been discointinued)
Posted on Oct 11, 2012
SOURCE: Need assembly instructions for Lady Anna dollhouse
I know this is a few months old... But I have the instructions and could scan them and email them to you if you still need them. Robsmith.nikon at gmail.com (in email format)
Posted on Oct 27, 2012
What to look for in bedroom furniture?
One of the best furniture that you can have in your bedroom is adjustable beds. These beds have so many advantages and are also known as electrical beds.
Adjustable beds contain movable parts like drawers and are very comfortable to use.
If you want to gain a full experience of using these beds at your home, you can get free home obligation service from the link mentioned above.
May 30, 2014 | Furniture
What is a tent inner kit?
The tent inner kit is the ultimate gazebo accessory; it's designed to suit all of the deluxe gazebos. It's constructed from tough fabric with water repellent treatment and sewn in PE floor.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
What is a screen house inner kit?
The screen house inner kit is designed to attach to the gazebo and cover it, it's constructed from ultra-fine mesh and features a sewn in heavy duty PE floor.
What's clothesline constructed of?
Camp clotheslines are usually constructed of sturdy aluminum and are capable of holding a reasonable amount of laundry. The string is usually some kind of a rope, a twine or a cored that is stretched between two points.
What materials are high chairs made of?
High chairs are made from either wood or plastic.
Aug 23, 2012 | Chicco Baby Gear
Bought the game at a yardsale, but no instructions.
I love how you do not include information about anything. You do not even post a question. Just tells us that you bougth a game at a yardsale. And that it had no instructions. Awesome!
Jun 23, 2011 | Video Game Consoles & Games
I bought repair kit for tv but need instructions for kit2052
I assume you bought it at TvRepairKits.com. Its printed on the sheet in the kit. Or go back to their site and ask for the instructions. Include your last name and zip code so that they can verify you ordered a kit.
Feb 19, 2010 | Mitsubishi WS-55809 55" Rear Projection...
No Manual
hello! the best thing you should see the store from where you have purchased your kit. most stores do includes manual which are clear and really handy and accurate..giving all the details on how to do that thing.. thanks! you may fix the other parts if no manual is available through simply doing it with a common sense..you just have to join it by using stick glue.
Apr 11, 2009 | Woodcraft Pirate Ship 3d Construction Kit
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
