WHEN TV IS ON THERE IS NO SOUND WHEN I TURN UP THE VOLUME I CAN SEE THE BAR GO UP AND THERE IS A SYMBOL OF HEADSET I THINK THIS IS THE CAUSE
    Sergeant:
  • 189 Answers
You're probably right. If you can't see any headphones sticking out of the TV, then you can probably set the audio to output through the speakers again through the TV's menu. It's probably under an Audio section or something. I'm not sure what kind of TV you have, so I'm sorry I couldn't be of more assistance.
Posted on Apr 10, 2011
The phone is connected to the device but sound wont go through to the headset why and how to fix
Turn your music or TV on your phone. Turn on headset. Turn on blu tooth. After headset connects, the sound should stop coming out of phone. Turn up volume on phone and headset. If this does not work, repair the headset to phone. Then repeat steps.
May 16, 2016 | Jabra headband for pro 9400 series 1412125
No sound from TV but if we connect headset sound comes from headset what is the solution
Check the settings in the "Audio" section on the menu on the TV. Check to make sure the TV speakers are in the "on" position in the menu and that the "Analog audio out" on the menu (if there is one in the menu), is set to "variable" if you are controlling the volume with the TV and not a sound bar.
Jan 23, 2016 | Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Lost sound dx4870
go into the control panel and go to sound and turn it on there
Dec 29, 2012 | Gateway DX4870 Desktop DX4870-UM20P
The volume up button on the remote and the tv are not working at all and the volume down button works but it does not turn the volume down instead it cycles through what seems to be different modes of...
SEEMS TO BE STUCK IN MENU MODE ,TRY PUSHING THE MENU KEY ON YOUR REMOTE AND THEN PUSH IT AGAIN,,HOPE THIS HELPS.YOU CAN ALSO HIT THE MENU BUTTON ON THE TV ITS ON THE LEFTHAND LAST BUTTON....
Jul 15, 2011 | Samsung CXD1342 13 in. Combo
Phone has no sound won't ring menu screen is fine everything is there but sound. Volume button is all the way up. Help
it might think it has a stereo headset plugged into it. If so it will have a little headset symbol in the upper righthand corner. Mine does this now and I can only use it with a bluetooth headset
Mar 27, 2010 | Pantech C610 Cell Phone
Volume from TV and Cordless headset, only want it in headset
Cordless phones are often of the infra red type and can be connected directly to the AV line out sockets (rca or scart, left/right audio out) on your TV or VCR. Since the audio is taken off prior to the TV sets volume control it is at a fixed output level. You can then turn down or mute the volume on your TV without affecting your phones sound level.
Mar 17, 2010 | Audio Players & Recorders
I am trying to figure out how I can prevent the sound of the game from coming out the tv. I just purchased turtle beach headphones but the sound of the game is still coming out the speakers of the tv also....
When you set the headset up following the instructions in the User Guide, you'll have both the headset and the TV playing. All you need to do is turn off the headset to hear from the TV only, or turn down the volume on the TV to hear from the headset only.
Jan 24, 2010 | Microsoft Windows XP Professional for PC
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
12 people viewed this question
 Grubhead
Grubhead
