Question about Amana ABB2227DE Bottom Freezer Refrigerator
Refrigerator is actually an ARB2217 with warm refrigerator/cold freezer
Our fridge is about 5 years old and in the past few days we've noticed that the top refrigerator portion is not very cold, no matter where we set the temperature dial. The freezer, though, seems fine and normal. I've read a bit online and tried to see that the baffles were not blocked (I don't think they are - we've emptied a fair amount of stuff out of the unit with not change in temp) or maybe the defrost timer isn't working. There does seem to be a little bit of frost at the very back of the freezer compartment, behind the pull-out drawer, but I can't tell what's normal. We've recently had a service call out to look at an occasional (large) leak from the ice maker. He replaced the valve for the icemaker, but it still seems to leak anyway. We're scheduling another service call, but I'm not optimistic that they're getting to the root of the problem and actually may have made it worse.
Thoughts?
Thanks,
Kurt
Buy an LG refrig!!! We just got rid of our Amana 2217 for the same reason...poor quality!!!!
We just bought an LG...the same one our friends have...no problems!!!
Posted on Jul 10, 2009
  • 749 Answers
I had a Freezer... recommend to change the coils or make another tubing that would replace the leaking area, then to replace the freon or coolant... then they have to make sure that they would place in the right amount of coolant or else the freezer won't work perfectly.
Posted on Aug 07, 2008
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Fridge and freezer warm. Mildly cooler air is coming out but the settings are on 7 for both fridge and freezer which are the coldest. Hard to tell if its actually cooler air or just seems that way because...
heatman101
Jun 02, 2011 | Maytag MFD2560HES Bottom Freezer French...
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the line...call a tech out and have it checked...it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Amana ABB2227DE Bottom Freezer Refrigerator Logo
534 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
