Question about Maxent MX-42VM7 42 in. HD-Ready Plasma Television
Picture size don't go to the sides about 3" black
  • 84 Answers
Go under the display settings you probably have it set to native mode which if it was set up for non wide screen televisions will display with black border on the left and the right. You will need to change modes if you want the black to disappear
Posted on Apr 10, 2011
Testimonial: "FIXED THE PROBLEM THANK YOU VERY MUCH"
  • Juan Torres
    Juan Torres Apr 11, 2011
    Your Welcome and glad I could help!!!!!
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
How do i get the viewfinder to show fullscreen. At the moment there are 2 black strips down each side in "iauto" mode. When i first had the camera it was fullscreen. Thank you.
The LCD screen on the Olympus SP-800uz camera is widescreen (16:9).
If you set the camera to take pictures in (4:3) ratio you het the black sides.
Solution:
Select a Widescreen Image Size (see the manual page 30) by selecting one of
the available Image Size settings 16:9 (L) (4288×2416) or 16:9 (S) (1920×1080).
Jun 12, 2011 | Olympus SP800UZ Digital Camera
My Trinitron's mostly fine, though it's a few years old, but it has a strange display issue. It's almost as though the picture is "zoomed in" about 8%, cutting off about 1 to 1 1/2 inches of...
This problems u are having it is not the causes by the tv,because ur tv it is a analoge CRT tv,don't have this functions zooming in or out or the problems just causes only 8% cutting off edges of the tv pictures only.If the problem it is happening to ur analoge tv it will have no vertical hold at all.The devices u are connected to the tv and using have zoomming in or out buttons or ajustment buttons of the sizes of the picture on the screen.Used the devices remotes controls to readjust ur zooming or pictures sizes adjutment.
May 04, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
How to down load the pictures on to my pc
hi, scuse me but i thing you will have more chance if you aske your question in the problem section
Nov 13, 2009 | Cameras
Black Box in the center of the picture
It's the text screen
remove by using the top left hand
side button on remote.
help me aftervpower off by cable co installer
now have NO sound
but have the sound register graph rising 0 - 50
Mar 28, 2008 | JVC AV-32330 32" TV
Maxent MX-42VM7 42 in. HD-Ready Plasma Television Logo
134 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
