Question about GE 30 in. Profile JP350 Electric Cooktop
Burner stays at high setting no matter what
One of the burners on my JP350 comes on but goes full bore and can not be controlled.  Figure it might be the control switch that is bad, but having problems identifying the exact switch part number I need.  It is the front right burner that can also be switched to a smaller heated surface area.
Can anyone identify the part I need to find?
  • 2 more comments
  • 5birds Aug 16, 2008
    I have the exact same problem with the exact same burner and GE model cooktop. If anyone knows how to fix this problem, please let me know. Thanks!
  • 6MG2 Jan 11, 2009
    I have the same problem- burner stays on high and that is the most used burner - front right.
    Can you fix yourself?
  • mhvizdos Jan 21, 2009
    I have the same problem. It is with the dual diameter burner. It tripped the breaker once. Also the burner on indicator remains very dimly lit when all burners are off.
  • Anonymous Feb 16, 2009
    I have the same problem with the same right front burner. Stays on high no matter where I turn knob.
SOURCE:
  • 59 Answers
SOURCE: only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Posted on Jul 19, 2008
aborcass
  • 2651 Answers
SOURCE: Dual Surface Selector Switch
more common is the dual switch to be bad, but it is possible that the elemnt itself has burnt out, usually a 5 yr warr on the elemnts under glass
Posted on Nov 09, 2008
  • 222 Answers
SOURCE: burner not working
try to clean the injector if no gas came out.or try to use matches to have a flame, i think there a problem in ur spark igniter if the gas is going out.tnx
Posted on Dec 02, 2008
  • 338 Answers
SOURCE: changing the surface burner spark electrode for GE stovetop
Schematic -
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGP326WEV1WW&productCategoryId=0121050&brandId=0432&modelName=GAS-COOKTOP&diagramPageId=00001&componentDescription=COOKTOP&documentId=10053061&backToLink=Return%20to%20Sub%20Components%20list
Posted on Dec 07, 2008
  • 93 Answers
SOURCE: Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Posted on Mar 15, 2009
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
JP350.. Large burner (front right) only the inner circle lights up no matter where the switch is set (large or small). Bill [email protected]
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ewrwer
werwer
Dec 23, 2010 | GE 30 in. Profile JP350 Electric Cooktop
The right front burner will only run on high no matter the setting
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You will need to remove the cook top from the opening to access the switch.You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 06, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
My dual size burner only goes large no matter the
You will have to have the potentiometer switch replaced that controls the burner.
Aug 30, 2009 | Jenn-Air Cooktops
Burner not working
Nov 22, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
GE 30 in. Profile JP350 Electric Cooktop Logo
135 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
