SOURCE: 665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
SOURCE: Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
SOURCE: clean light blinks 7 times after going through
this error says that there is a fault in the heater circuit. the heater circiut goes thru the doorlock assembly, thermostat(if equipped) then heater and back to the board.
do you see or feel and rough spots on the surface of the heater? if so it is probably burned out. if thats not it i would check continuity on the door switches, then the thermostat and the heater.
levi
Lebarchrigen Appliance Repair
www.lartoday.com
Testimonial: "thanks for the info ill see if i can work through it now!"
SOURCE: Dishwasher 66516039 won't run very long and the
Need to know make and model
regards, service gnome
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
