When i turn it on it comes up and says diskette drive A error...i try to go to last known good config and it then brings up the sindows page then goes back to the error
    Genius:
  • 1,689 Answers
It will be best if you disconnect the power and the data cable out of the Drive A: or your disket, then try to reboot. you may try to reinstall the drive later on on safe mode once your PC is error free.
Posted on Aug 07, 2008
My computer wont turn on after kids used it keeps going to launch repair page but then wont do anything else.
If you're using window xp/2000 you can try using the last known configuration option. Here are the instructions:
To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting repeatedly press the F8 Key, which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow key to move to "Last Known Good Configuration" and press your Enter key.
Jun 05, 2011 | Acer Aspire X3200 PC Desktop
When I turn on my acer netbook a message comes on that says a recent hardware or software change might have caused windows not to start successfully.
It sounds like a software or driver problem.
You could try running Last Known Good Configuration and see if rolling back to a known good will work.
This video will help you to run last known good configuration, it shows Windows 7 but if your not running Windows 7 all the versions of Windows run last known good config in the same way.
Jan 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a dell studio that says A disc read error when you turn it on , shop told me hard drive gone ,, i am running a pre boot ssytem assesment from pressing f12 and the test say DST short test pass does...
TRY F8 ON BOOT UP TAPP REALLEY FAST IF U CATCH IT INTIME GO TO OPTION LAST KNOWN GOOD CONFIG .....ONCE IT DONE LET IT DO ITS THING IF IT BOOTS LET IT ..THEN ON FULL BOOT LEAVE MIN OR 2 THEN RESTART UR SYSTEM .....SEE IF ANY DIFFRENT
Jan 09, 2011 | Computers & Internet
On my emachines d520 running windows xp the system hangs up at boot and gives this error message.
hit the R key many times when booting up and will bring you to the recovery tool and try the options it allows you to like (last known good config.), (safe mode) do a virus scan then when you get in, and or a restore from there ok try these and if nothing works then shoot me the error code it's giving you and I go from there ok good luck and have a nice day the fixist
Jun 26, 2010 | Computers & Internet
My computer froze during shut down, so I turned it off using the power button. When I start it up It gives me the options of starting normally, Last known good configuration, safe mode safe mode with...
Try go into BIOS by hitting the DEL key or F1 or F2 as you start and go to save Cmos config. then reboot.
The other approach is Last known Good config is the best. This can be brought up after presing power button then by tapping F8 till screen apears.. Select Last known Good Config
Nov 08, 2009 | Sony VAIO VGC-RA840G PC Desktop
The tool could not get HDD physical information.
Laptop hard drives are usually the 1st to go when it comes to issues with laptops.
I would recommend replacing it. Roughly 50 bucks for a 40 or 60Gb laptop Hard drive. Install it and try your recovery cd again.
My wifes laptop is from 2001 and it has gone through 2 hard drives. Its just the way they are. Backup data, always!
G'luck
Oct 23, 2008 | Toshiba Satellite A105 Notebook
Diskette drive 0 seek failure
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
Floppy diskette seek failure
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Notebook won't start
press the key F1 or F2 or F10 or DELETE when you try to restart your computer before 5 seconds that will open the BIOS page so go to boot order and change it instead of start with cd flopy hard drive put the hard drive first save it and restart the computer it have to work good un less there is a problem with your hard drive or windows software if that is the case restart the computer and press F8 before 5 seconds and you'll see black page with the next options last know good config and save mode click on last an then restart the computer if does not work try save mode of you can acces tue hard drive that means bad windows software if not bad hard drive
Jan 02, 2008 | HP Pavilion zd8000 Notebook
Computer won't reboot
Check your BIOS settings, specifically the diskette drive setting. Next, check the cabling to the drive itself. Your problem may have nothing to do with the diskette drive, but check it out. Next, have someone download hard drive diagnostics for the brand of drive in the machine. You could have errors on the drive, and a diagnostic program may locate, repair them. The startup disks, these do a full system restore, reinstall of the operating system? The machine will boot from the first startup disk and begin the reload process?
Sep 12, 2007 | E-Machines etower 400i3 PC Desktop
Computers & Internet Logo
David Payne
David Payne
