Question about GE Ovens
Wall oven flashing f3 and beeping - GE Ovens
    Sergeant:
    Champion:
  • 202 Answers
Use a ohm meter to test the sensor, it should read about 1100 ohms at room temperature, if so, then your oven sensor is good.
If your oven sensor tests good, then your control board would need to be replaced.
Posted on Apr 10, 2011
Oven beeps and show F1 and F3 while trying to cook or even 2hrs after cooking.
F1 code is a "EOC (Electronic Oven Control) failure" Replace your oven control
F3 code is a bad oven sensor the sensor should have a ohm reading of 1100 at room temp. Replace your oven sensor as well.
Dec 06, 2010 | Frigidaire 30" Built-In Single Electric...
F3 keeps flashing on the display
F3 or F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | GE 30" Built-In Single Electric Wall Oven...
Oven beeps and display read "F3". what does this mean?
Hi dpaulthomas,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to resolve this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Aug 31, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
Flashes f-3
you have a bad oven temp sensor probe
Jun 19, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
Ovens Logo
59 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
