What do's the code f21 code mean - Washing Machines
    Sergeant:
    Champion:
  • 202 Answers
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Apr 10, 2011
I have F21 on my machine, how can I fix it?
The F21 error is generally related to the drain of the washing machine (depending on the brand of your machine). Basically it means that the drain is clogged and the machine is taking too long to empty the water out.
Cleaning the drain is not for the queasy. You can find information on how to clean out the drain by visiting: http://www.kiwiservices.com/angela-says/fix-an-f21-code/
Apr 07, 2017 | Washing Machines
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
Whirlpool washer wfw8300sw02 code F21 what does that mean
the F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
c...
Feb 03, 2011 | Whirlpool Washing Machines
What does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Keeps on coding F21 - we have adjusted the hose several times but still seems to be giving us problems
Hi
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
What does f21 mean
an error code f21 means your machine may not be draining properly , it may have a kinked or bent hose that is keeping the water from flowing completely. check the back of the machine unkink it or replace it. good luck!
Dec 30, 2010 | Maytag Washing Machines
What does the code F21 mean?
F21 Long drain Possible cause: Clogged filter, clogged/failed pump, suds detected by control.cf69491.jpg5c302b4.jpg0a85b76.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2010 | Whirlpool Washing Machines
F21 code flashes
Lets see what an F-21 is shall we? F21 Long drain Possible cause: Clogged filter, clogged/failed pump, suds detected by control.3a5b94a.jpgb4a897e.jpg55f108d.jpg
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
kinked.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
