Question about Samsung SyncMaster 932B LCD Monitor
Sometimes after my screen goes to sleep mode, when I move the mouse to awaken it, the monitor gives me a high pitched noise and shows the image for a second, and then goes to black. I have to turn the monitor on and off a few times before this clears and it stays on. What can I do to fix this?
  • 40 Answers
Can't be sure before I see it, but sounds like capacitor(s) are burned out. If it is possible to open it ip, do it after you have removed all power sources. Burned out capacitors look something like this: http://www.gator-byte.com/wp-content/uploads/2007/10/capacitor.jpg
The smaller one in the picture is fine.
It doesnt have to be messy at all, but notice the bellying top.
If there is your problem, you have 2 choices...
1) You find somebody who is able to change capacitors and let him/her do it.
2) You buy new monitor or just use the old one.
Changing capacitors can be tricky at times and might be expensive.
Posted on Apr 10, 2011
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
LCD monitor turn to sleep mode
Does it turn off or go to sleep? If it turns off , there may be a setting that needs to be reset or reprogrammed. If it goes to sleep because of inactivity, just move mouse to awaken it
Sep 27, 2012 | Vocopro Ltv-5 LCD Display System
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
The blue light around the power button is doing a slow blink, the pc is up and there is no picture on the monitor.
The computer is "sleeping", in power-saving mode.
Touch any key, or wiggle the mouse, to awaken it.
Or, touch the on/off button, to awaken it.
Aug 21, 2010 | Samsung Computers & Internet
Monitor does awake from sleep mode
You need to check the inverter fuse, transistors, caps, solder joints. Please see my pictures here to get some ideas so you will know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Please post back.
Replacement board: http://www.lcdrepair.us
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
When I awaken my computer by moving the mouse the LCD light on the monitor keeps blinking off and on for over a minute before the screen comes on.
Delays are common for systems coming out of sleep mode and it isn't only the system box that must wake up but the monitor also samples its input to determine if a signal is present before it comes out of a power saving mode.
If the monitor is a CRT unit, the jug needs some time for the heater to warm up and emit electrons again, if an LCD, the fluorescent backlight and its circuit can have delays too.
Admitted, a minute seems a bit long but may just be the combined characteristics of your system and monitor.
It still beats booting up from scratch.
Aug 13, 2008 | Computers & Internet
New flat screen monitor humming noise
This could well be your refresh rate. Move your mouse pointer over any blank area of the screen and right click. Highlight and click on properties.Click on the settings tab, then on advanced then on to the monitor tab. You should see a setting for refresh rate eg. 75 Hertz. Change the refresh rate and the noise should disappear.
Jun 30, 2007 | Samsung 920BW (Black) Monitor
Samsung SyncMaster 932B LCD Monitor Logo
195 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
