Question about Kodak EASYSHARE 5100 All-In-One Printer
Trying to scan pictures it will scan but then i cant find it after to show up on the screen
CANT FIND MY DIRECTIONS-HOW DO I SCAN A PICTURE?
Hi k_eddings06,
Based on your concern, i suggest tyring these steps:
1. Place the item you intend to scan in the appropriate place.
2. Locate the HP Solution Center programme, which may be accessible from a desktop icon.
3. Open up this programme by double-clicking on the icon, to enable you to scan and modify your picture.
4. Click on 'Scan Picture' Click 'Scan', and 'Accept' on the next screen to begin scanning the image on the printer.
5. You will then be able to modify the picture, crop as desired, and export to various programmes and formats as desired.You may also be able to print directly from this screen if required.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
Jan 21, 2011 | HP PSC 1510 All-In-One InkJet Printer
I have the 52 inch home theater and the picture shifted and is shows the picture but half way because the top of the screen shows black
hi,
you could try resoldering the vertical scan ic and changing electrolytic capacitors near it, as they have probably dried out due to the heat over the years. cant give you the position numbers as i have no manual but the ic should be on a heatsink on the deflection board,usually vertically mounted and with 5-9 leg.
ok
Dec 23, 2010 | RCA P52926 52" Rear Projection Television
Cant go to picture mode, error on screen shoes
try to remove the battery first for a few minutes...then retry. This might help reset the system
Aug 10, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
My kodak scanner won't scan but will print pictures
connect ur printer to ur computer and then try to scan any document or plug in any memory card and then press scan .it will ask u to save the file after scanning, save it on computer. ur issue will be resolved
Jul 20, 2009 | Kodak ESP 5 Printer
Picture not on whole screen
have you another disc?
some movies are formatted.try to press set-up button on your dvd remote.choose video or tv types.it shows letter box or LB, pan and scan , and 16/9 for widescreen
May 07, 2009 | Philips DVP5990 DVD Player
I cant scan my pictures
This is the link for the guide on the printer: http://support.dell.com/support/edocs/systems/PRN922/en/OM/922_en.pdf
Page 21 of the guide shows you how to scan and copy.
Jan 12, 2009 | Dell 922 All-In-One InkJet Printer
Printer won't scan a picture
I had the same problem, but I was able to scan my first photo today. If you are using Windows Vista and have Windows Photo Gallery on your system, you should be able to scan your photo/documents. Open Windows Photo Gallery 1. Click File, and then click Import from Camera or Scanner.
2. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
The rest should be self explanatory. Good luck!
Jun 17, 2008 | Canon Pixma MP500 All-In-One InkJet...
Stuck on P-Scan
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 25, 2008 | Memorex Progressive Scan DVD Player...
Brother printer-wont send my pictures to the computer screen
You should uninstall then reinstall your printer making sure you turned on the scanning feature.If that does not help you have a programing problem.
Oct 18, 2007 | Office Equipment & Supplies
After i scan a document, the image appear in black screen. Why?
uninstall the software from pc and turn off. then restart and re-install software.
Jun 01, 2007 | Canon CanoScan 5000F Flatbed Scanner
Kodak EASYSHARE 5100 All-In-One Printer Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
