Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Need to no where the oil drain plug is - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
  • 126 Answers
Looking at the front of the engine it will be in the left side on the bottom it will be a brass 90 with a piece on the end that u will have to push up on and twist then pull down when u do this it will start draining u should have a small 1/2" hose that should fit on this so u don't have oil going all over the place .hope this helps
Posted on Apr 10, 2011
Oil change 1994 Cadillac Eldorado
well let me see you have 4.6L engine you need 7.5 quarts of oil with new oil filter.to do the oil change you need large drain pan and oil filter wrench and a metric wrench to remove oil drain plug you need a funnel also.you need first start engine let it run for 5 minutes to warm up thin out the oil so it will flow better.once engine warm up.turn off the engine.open you hood.now safely raise support vechicle on jack stands make sure vechicle parked on solid level ground.place large drain pan under oil pan remove oil drain plug you need a 15m wrench remove drain plug let all old oil drain out until you see slow drip then reinstall oil drain plug dont over tighten drain bolt.then place drain pan under the oil filter then remove oil filter using oil filter wrench or large channel lock pliers.once you remove oil filter wipe oil filter seal surface with clean paper towel.take new oil filter add oil to new filter then install new oil filter hand tight take filter wrench turn oil filter one half more turn dont over tighten will damage oil filter seal.make sure oil pan drain plug is in place. then lower vechicle. remove oil filler cap on the valve cover add new oil to the engine using a funnel to keep from spilling oil all over the valve cover and exhaust manifold.add all 7.5 quarts to oil crank case wait until oil settle down in crank case check oil dip stick oil level should be at the full mark on oil dip stick.dont over fill crank case.once you finished oil level correct crank engine check for oil leaks at oil filter and oil drain plug. if engine running okay you see no oil warning lights you ready wheel and deal.
Nov 20, 2011 | 1994 Cadillac Eldorado
Tip
How to change your oil in 3 easy steps
(1) Getting Ready When getting ready, it is important to have the right tools and materials on hand, such as jack stands, a socket set and an oil drain pan. Let your Car engine run for 10 minutes before you drain the oil since warm oil is easier to drain than cold. Make sure you park on a level surface or, if your car has a low clearance, jack it up or drive it onto a ramp. If youre jacking up the car, use two jack stands instead of one. check the type of filter you need against the make and model of your vehicle
(2) Draining the Oil and Changing the Oil Filter To drain the oil, crawl under the car and look for the oil drain plug under the engine near the front of the car. Position your pan beneath the plug then use a socket or spanner to loosen the plug, turning counterclockwise. Once loosened, you can use your hand to remove the plug and the hot oil starts pouring out. Make sure all the old oil is drained into the pan. Once its completely drained, wipe the drain plug and the plug opening. Now replace the drain plug gasket and use a wrench to reinstall the plug but dont make it too tight.
Next, look for the oil filter. They are usually at the side of the engine. Place the oil pan beneath the filter in case any oil remains. Unscrew the oil filter (use gloves if it is too hot) and wipe the filter area clean, especially where it mounts to the engine. Dab a bit of your new oil on the rubber seal of the new filter and then screw it in by hand. You dont have to use a filter wrench to tighten the oil filter.
(3) Installing New Oil Remove the oil filler cap thats located at the top of the engine. Position the funnel at the opening and slowly start pouring in the new oil You might want to check your manual for the proper oil capacity but, typically, you will need three or four litres of oil. Once youre done, put back the oil filler cap. Start the engine, let it run for a minute and then check the dipstick. If you need to, add more oil. Now check for any leaks near the oil drain plug and the filter. If you do find leaks, simply tighten the plug or oil filter.
Youre done.
on Mar 18, 2010 | Ford Escort Cars & Trucks
I added oil to my Cadillac and it drained onto the ground
Before adding any more oil, make sure that you have securly replaced and tightened the oil drain plug (which is located on your engine's oil pan, under your car).
The FixYa Team!
Feb 01, 2011 | 1996 Cadillac DeVille
Where is oil plug on a 2005 volkswagen jetta and what tool is needed?
Should be on the back side of the oil pan about dead center. At least for the 1.8 and 2.0 liter engines. You will need a 19mm wrench or socket (if its the O.E. drain plug). Be careful when tightening the drain plug after draining the oil. The oil pan is aluminum and we replace a fair amount of them because the threads for the drain plug are stripped out. The drain plug only needs to be torqued to 22 ft-lb.
Nov 10, 2010 | 2005 Volkswagen Jetta
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
Aug 11, 2010 | 1991 Oldsmobile Cutlass Calais
Need to know where the velve is to release oil
Underneath the engine you will see an oil sump pan. It will have a drain plug that you can use to drain some or all of the oil. Loosen it slowly and oil will begin to drain. As soon as you have the amount out that you wish to drain, tighten the plug.
Nov 26, 2009 | 2001 Pontiac Grand Am SE
Change the oil on a 2000 Dodge Caravan
Jack up pass side.Put cardboard, BIG piece under engine just in case. Using a pan to drain the oil in put under oil pan drain plug. Remove drain plug with socket wrench. Let drain 5 min. Check the gasket on the drain plug, if bad replace with new gasket .99 cents to replace gasket only on plug. Put plug back in DO NOT OVER TIGHTEN the plug. Slide drain pan with drained oil to the front to remove oil filter. Using a filter wrench remove oil filter. Let drain. When installing new filter put a little new engine oil on the rubber gasket on the filter with your finger. Screw filter back on tighten with filter wrench. Fill van with oil from front valve cover opening.
Nov 21, 2009 | 2000 Dodge Caravan
1994 nissan pulsar import. Need to know how to do a oil change thanks
remove oil pan drain plug, drain oil. check gasket on drain plug re-install drain plug , fill oil to correct level.
Aug 12, 2009 | 1990 Nissan Pulsar
Need instructions for doing an oil change.
For doing on oil charge need to waste oilbasin ,new oil filter ,new oil canister.After that you need to run genine whith oil cleaner atleast 10 minutes,after wentilaiting ,stop the engine ,open drain plug and drain derty oil in waste oil basin,close drain plug, replase old oil filter ,fill in new oil.
Aug 09, 2009 | 2005 Mazda Tribute
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
