Question about Goldstar Heating & Cooling
I need to know how much freon it takes to recharge a goldstar room air condioner. model number 5dex2070. serial number 512 TARU 00342
    President:
  • 1,515 Answers
Hi, you need to locate the data plate for this unit. It will have the voltage, amps for compressor and blower motor, freon amount in pounds and oz., . If this is a older unit, it will be R-22 refrigerant. A new one will have 134-A, R-404, FX56, and so on. If you are going to charge this yourself, and it has no freon in it at all, you will need to find and repair the leak first. If you have done this already, you will need to pull a vac on the unit to remove any air and moisture that has entered the unit from the leak. This is a MUST!! You say it is a room a/c, so it will not hold very much, more like ounces. If there are service valves on the unit to charge it, and you have the gauges to do this, you can charge it without knowing the amount it holds. According to the type freon, use the scales on the low side gauge to get your evaporator temperature at around 40 degrees F. The pressure will be at around 68p.s.i.. I hope this has been of help to you. You need to have some no how to be able to do this properly. Good Luck, and please keep me posted.
Shastalaker7
A/C, and Heating Contractor
Posted on Apr 10, 2011
My ac is not cold???
Check freon. Sounds like it's low pressure. Could need to be recharged.
Jul 14, 2014 | Goldstar Heating & Cooling
The air from my air conditioner doesn't seem to be coming out as cold as it was when i first bought it. It seems to take a lot longer to cool off my living room, i dont know if it needs freon to be...
Its going to take a hile to cool down a hot room . have you cehck the filter? while your at it wash it out . what is the temp of the room and the temp of the air coming out of the unit?
Jul 22, 2011 | Goldstar Heating & Cooling
I HAVE A 220 ROOM GOLDSTAR AIR CONDITIONER. THE FREON LINE HAS RUBBED AGAINST SOMETHING AND HAD A PINHOLE LEAK. THAT LEAK HAS BEEN REPAIRED AND AN AIR CONDIONER TECH FROM CHURCH IS GOING TO RECHARGE IT FOR...
Hi, if he is a a/c tech, he had to use silver solder to repair the leak. If he is using manifold gauges, he can charge it with out knowing the amount to put in by looking for how much it takes. The unit needs/HAS to be evacuated first! He can charge in the freon using the chart on his low side gauge, as he wants the evaporator temperature to be at 40degrees F, with the P.S.I. at 68 for R-22. Just start charging in, using gas not liquid slowly, watching the suction line, and stop when it starts to condensation the line. If the top of the compressor starts to condensate, it is over charged. I wish you the best.
Shastalaker7
A/C, & Heating Contractor
Apr 10, 2011 | Goldstar Heating & Cooling
Ac not cold
mcdevito75 here 90% chance your low on freon, you don"t cahrge it the a.c repair shop does, you"d need the gas first and it's a commercial item then the tools would cost you the same if you charged it anyway and the shop gives a guarantee.
Jun 21, 2010 | Goldstar M5200R Air Conditioner
Room does not cool down
It may be low on freon or have a leak, I'm not sure if that particular unit has Service Ports on it to enable a recharge, consult your Owner's Manual for any Troubleshooting Tips. www.goldstar.com
Jun 05, 2010 | Goldstar KG6000R Window Air Conditioner
When turning the theromostat to 9 it doesn't cool the room.the fan just runs.
the system either low on freon or you have a bad leak. If its low or have no freon the unit will keep running. have the unit recharge and check for leaks.
Aug 24, 2009 | Goldstar R5208 Air Conditioner
Air conditoner model gwhd5000 goldstar does not cool
Hi, first you will need to know, what type refrigerant,(freon) your a/c used, if you need to add freon, there's a leak in your a/c. you will have to find and repair leak, before you can charge/ add refrigerant(freon) . automobile a/c can be easily recharge (add) to system, but your window a/c unit, has the same principles but different approach, if you don't have experience, you will have to call mechanic, make sure you have a freon leak, before calling mechanic, plug a/c on let it work, put hands close to a/c, feel or check temperature of air blowing out from a/c, make sure compressor is working/running, fans could be working/ but compressor not, also put a/c thermostat to max, your model no. GWHD5000. means your unit is 5000 b.t.u, (british thermal unit) measurement of heat transfer, am wondering if a/c is to small for your space/room. making you think it needs freon, 5000. b.t.u. is for a small space,like a room 10' by 10' like a storage area or small bedroom, keep bedroom door/windows shut. measure you room/space/area , the bigger space/area needed to be cooled, has a chart, maybe you can find it on internet, any way a 10.000 or 12.000 b.t.u a/c is better buy, for normal room/space etc. so check compressor especially to make sure working, a/c could be to small for space/room, check it at night to see if it's colder. don't try to put gas/ freon yourself, could be very dangerous. but before calling mechanic, check those thing, mention before, could be your a/c are to small, for space/room etc. remember before attempting any repairs, disconnect power. good luck.
Aug 20, 2009 | LG Goldstar GWHD5000 wall/window Air...
Why will a room air conditioner ice up and can I fix the problem?
Freon leak, How new is it. If you still have a warranty take it back and have them replace it. If it is not under warranty you can try a few tricks. Clean the outside coils with a strong blast of water with the unit off and make sure the filter is cleaned
May 24, 2009 | Goldstar LG LUCKY WG1800R Room Air...
How do i add coolant to the ac
First before adding freon is the compressor and fan running? Second, is both the condenser nd evap free from dirt? Please advise, RepairUSA
Aug 30, 2007 | Samsung AW0603B Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
