Question about Seagate Barracuda 7200.9 80 GB Hard Drive
Trying to make my seagate barracuda 7200.9 slave
    President:
  • 2,340 Answers
There are 2 types of interfaces for your mentioned HDD "Seagate barracuda 7200.9" ie PATA & SATA intefaces!
If it is IDE ie PATA interface, you just set the jumper to Slave.
If it is SATA, interface, You cannot "SLAVE" a SATA drive. All SATA controllers are stand alone. You just plug it into the Sata slot available & power cable to the HDD. Be sure that the HDD is partition & formatted so that your system can detect the HDD.
Hope it helps.
Posted on Apr 10, 2011
  • 40 Answers
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
4 Suggested Answers
Psionics
  • 236 Answers
SOURCE: how to tell which jumper is master and which is slave
Master is 7-8 (the 2 furthest from the power connector)
Slave is no jumpers selected
Here is a manual for your model for reference:
http://www.seagate.com/support/disc/iguides/ata/cuda7200ig.pdf
Posted on Mar 28, 2008
  • 11 Answers
SOURCE: SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Posted on Nov 24, 2008
SOURCE: firmware update for Seagate Barracuda 7200 10 80
Dear FixYa team,
Thx for your kind offering to me. I already call my friend to help me here. And he seems already found the solution. The problem was comes from USB cable malfuction, and I think it somehow affect the firmware detection. Gladly he can back up it again with another harddisk, just try to baiting it to make the firmware read. Now I'm still waiting for data recovery only. I'm so sorry that I can't use ur helps now, coz I needed it in hurry. Thx
Regards,
Angeliczone
Posted on Jun 27, 2009
How do i set a seagate barracuda 7200 hd to slave
you don't need to setup as a Slave drive like IDE drives. You simply install the new SATA drive on an open port and follow the steps in this thread to format the hard drive. This will allow the hard drive to be used as a storage drive or whatever you plan to use it for.
Guide: If you installed a new disk but the system can't see it
May 11, 2014 | Compaq Presario SR1030NX (DW256A#ABA) PC...
How do I set my 7200 Seagate drive as slave
Look at the diagram on the drive, you will need a jumper
MA = Master
SL = Slave
CS = Cable Select
If it's EIDE use the center connector on the cable
Oct 25, 2009 | Seagate Barracuda 7200.10 750 GB SATA Hard...
Hard drive failure segate barracuda 7200.9 it is two disks raid striped is there any way to remove data from disk or any way to connect them to another machine as a slave
how about scanning and trying to repair the sectors with hirens boot cd. There is a utility on it called hd regenerator or something like that http://www.hiren.info/pages/bootcd. I think you have to download this cd from piratebay first. There is no download from his website.
Sep 14, 2009 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
SATA HDD make SLAVE
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to tell which jumper is master and which is slave
Mar 28, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 200 GB 7200 RPM
can you take a snapshot from the smart page?
Feb 22, 2008 | Seagate Barracuda 7200.7 200 GB Hard Drive
Seagate Barracuda 7200.9 80 GB Hard Drive Logo
1,083 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
