Question about Nitro Bmw-4741t In-dash Touch Screen Motorized Detachable Car Dvd, Cd, Mp3, Usb, Sd Player with 4.3" Tft Monitor Built-in + Am Fm Radio and Built in Tv Tuner and Built in Bluetooth with No Additional Accessories!
BMW-4741T how do you hook up or send GPS video to the unit
How come when ur on a blutooth call the person can not hear on their end
Posted on Sep 06, 2011
Nitro car stereo manuals
Need settings code for an Nitro BMWX-4756 300Watt 7" Touch Screen Monitor In Dash Din DVD CD AM FM for the gps, settings it's a 4 digit code to change GPS settings
May 01, 2015 | Nitro Bmw-4741t In-dash Touch Screen...
Hp 2 fuel gauge is not working
Hi, Anonymous you could have a faulty sending unit or gauge, there could be a problem with your wiring. On models with the fuel gauge posing as a left-hand fuel cap the gauge is a press fit do not try to unscrew it, simply ample force lift up in a rocking motion to remove gauge. Disconnect wires to the gauge and with a set of positive and negative jumpers from the battery connect the positive jumper and flash the negative, gauge should peg full, if not replace the gauge. With a test light check for power to the sending unit, then remove the sending unit and manually operate the float arm slowly with the correct wiring hooked up to the fuel gauge and sending unit and the ignition on, the gauge should respond accordingly if not replace the float arm assembly. If your fuel gauge registers the incorrect amount of fuel in the tank you can try bending the float arm the necessary amount for a more accurate reading. For more information about your issue, please visit the websites below. Good luck and have a nice day. Fuel gauge and the HP2
https://www.tradebit.com/filesharing.php/search/0/2008+bmw+hp2+enduro
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1 http://www.k100.biz/pdf/FAQ/FAQ_K100_tips.pdf
Sep 08, 2013 | 2008 BMW HP2 Enduro
Touch screen not working
Are you able to hook the unit up to the PC via USB, if you are able to get it into mass storage mode i would try giving the unit an update using Garmins WebUpdater Software. Here. If you are unable to connect it to the PC you may have to send it in for warranty or repair. And just to be clear when doing the hard reset are you powering down the unit and holding the bottom right corner on the touchscreen and then turning the GPS back on with your finger still in the bottom right position?
Be sure that the hard reset cannot be done before you send it away for warranty or repair.
Hope this helps!
Apr 26, 2011 | Garmin nuvi 205W GPS Receiver
I turned my gps on and all it does is flashes !
Hope this helps!
Apr 26, 2011 | Garmin n?vi 1100 GPS Receiver
I need to replace some of the wirers on the plug, could you tell me the wire configuration please and thank you for your help..
The Vehicle should a stereo harness outlet socket on which the new stereo should be connected least requirign wiring individual cables. Once the new stereo has been acquire from retail, a compartible cable socket connection between the parts in the vehicle with the new stereo should simple fit in place. Inquire from the auto retailers about the most available compartible socket cables connection to suit a BMW as the defautl vehicle to a new stereo device. Versatile connection socket connector cables would snap in place as compartible to any stereos.
Feb 09, 2011 | Nitro Bmw-4741t In-dash Touch Screen...
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
Every time i turn on my lowrance 520c it says gps module not resp
I had the same problem. Sent my entire unit back to Lowrance, but they said it was fine. One year later, I find out that I did not receive or have the correct parts to hook up the GPS unit. I needed the NMEA 2000 T connector and terminator plugs. Look at your manual and hook it up the way the manual says. It will require a NMEA 2000 T and at least one 60 ohm terminator plug. Seems the GPS module sends back some kind of signal that if not absorbed by this thing will mess up your unit. Mine works since I got it hooked up correctly. HD
Jul 17, 2009 | Lowrance LGC-3000 GPS ANTENNA FOR UNITS...
BMW gps crashed after inserting copy
yes have right and this can cost you lots of money.i will remove the unit and ask a radio shop to open it and remove the cd copy right a cd can no work in the bmw units and for just paying the little extra you would have enjoyed the nav unit even more
May 02, 2009 | SNK Navtour G4 4 GPS Receiver
I dropped my garmin nuvi and the power button is jammed in...am i hopeless?
Try to use a dental tool (small hook-pick) to pull it back out, otherwise send it back for repair.
Jan 27, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nitro Bmw-4741t In-dash Touch Screen Motorized Detachable Car Dvd, Cd, Mp3, Usb, Sd Player with 4.3" Tft Monitor Built-in + Am Fm Radio and Built in Tv Tuner and Built in Bluetooth with No Additional Accessories! Logo
239 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
