Question about RCA Televison & Video
Our RCA DLP has a loud hum when it is turned on, but goes away when it warms up. What is goint out?
    Sergeant:
  • 189 Answers
It's' just the lamp warming up. It usually takes about 30 seconds for a DLP to start up. This is nothing to worry about.
Posted on Apr 10, 2011
Testimonial: "I have quit holding my breath-thanks"
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
I have a loud humming noise comeing from my tv
Check power supply filter capacitor that goes to Audio IC.
Apr 02, 2010 | Samsung DLP HL-P5663W 56" TV
I have a 52" rear projection vivitek dlp tv. Picture is fine, but it has a loud humming sound. Does anyone know what it is or how to fix it??
turn on video mode if loud humming still occurred replace filter capacitor on audio section from your tv ckt board.
Mar 31, 2010 | Vivitek V37655 56" DLP TV
When i put the tv on there is a loud humming as the tv warms the
could be a fault in the mains power-supply section,
Oct 13, 2009 | Televison & Video
Loud Humming
Many times a "humming"sound is caused by bad signal, caused by things like, bad rca cable, bad rca ground from the radio, or even a bad ground in from the amp to the car.. Wiggle your rca cables at the input to the amp, and see if it changes the hum at all.. If not take a short peice of speaker wire, and wrap one side arrounf the outside metal at the end fo the RCA jack, and then touch the other end to ground, and see if that makes the humm go away. If the humm goes away at that point then you need to have your radio replaced, or repaired. if neither of these do anything to the hum then check for tight ground connection to the amp, and to the car..
There could also be a problem with the amp it's self, but this kind of thing is hard to diagnose over the web, so try those things, and let me know what happens..
Aug 15, 2009 | JBL Audio Players & Recorders
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Tv has what sounds like a humming noise by where the bulb is
sounds like the color wheel problem.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Dec 11, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
