Question about Bernina Bernette 75
My Bernette 203 will not cut the material or thread. I need to know the correct placement of the cutting knives.
    Scholar:
  • 89 Answers
First to see if the top blade is pressing against the lower blade when it goes past to make the cut.
You should be able to push the top blade to the right and have it spring back to the left. Do that to see if there is a small amount of presser on the lower blade.
Next, the cutting part of the top blade should drop just under the lower blade buy about 2 mil.
Also the lower blade should be level with the needle/stitch plate.
Blades also may need sharpened. The top one can be done with just about any sharpening tool but the botom is carbide so you will need a dimond wheel to sharpen it
Hope this helps
Posted on Apr 11, 2011
How to set Bernette serger 203 for rolled hem
Be sure you have the proper foot for your machine to make a rolled hem.
Bernette 203 How to use rolled hem foot have the one page manual but it...
Sew Inspired Serger Rolled Hem Tips
In case you don't have a manual, you may be able to glean some information here:
Sergers Overlockers
need manual for the Bernina Bernette 203 overlocker
Aug 31, 2016 | Bernina Sewing Machines
Why doesn't it cut threads?
Could possibly be an adjustment needed in the cutting apparatus.
Nov 21, 2015 | Sewing Machines
Why doesn't the cutting tool work automatically on the 4 thread overlock
You knives may be dull and need replacing or they may not be able to completely lower to complete the cut. Suggest removing thread and try feeding a piece of paper through the machine area. Watch the knives to determine if the top one comes all the way down to make a good cut. If it does not, there may be lint build up in the gears below. You can check it by opening the door to reveal the thread area below. Using hand wheel manually feed the piece of paper through and watch cutting gears. There is an opening above and below the screw that holds the gear in place. Take a needle or other sharp pointed tool and make sure that there is no lint in the area above the screw and below the screw. Many times, lint gets packed in that area and causes the gear not to lower completely.
Hope this makes sense. Otherwise, take it to an authorized Husqvarna Viking dealer for cleaning and service.
Oct 05, 2014 | Husqvarna Huskylock Computerized 936
How do I make the cutting tool work
Your knives may be dull and need replacing or they may not be able to completely lower to complete the cut. Suggest removing thread and try feeding a piece of paper through the machine area. Watch the knives to determine if the top one comes all the way down to make a good cut. If it does not, there may be lint build up in the gears below. You can check it by opening the door to reveal the thread area below. Using hand wheel manually feed the piece of paper through and watch cutting gears. There is an opening above and below the screw that holds the gear in place. Take a needle or other sharp pointed tool and make sure that there is no lint in the area above the screw and below the screw. Many times, lint gets packed in that area and causes the gear not to lower completely.
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
Threading bernette overlocker
have you tried the video's on youtube
Apr 06, 2012 | Bernina Sewing Machines
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Oct 14, 2009 | Husqvarna Huskylock Computerized 905
Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
May 12, 2009 | Bernina Bernette 75
Upper Knife
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
Sewing Machines Logo
546 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
