Question about HP Pavilion ZV5000 ZX5000 Compaq R3000t R3200 series 15.4-inch TFT WXGA LCD Display-350217-001 (350217001) CD-ROM Drive
Hp zv 5000 won't charge battery or turn on
Power light comes on on charger and charge light on machine. doesn't have enought power to turn on. unit will turn on breifly without charger but doesn't stay on long enought to boot windows
  • heckler0 Aug 24, 2008
    Looking at the same model for a co-worker. Charge light comes on, but pressing the power button only results in a half-second of lights and then turns off. Person also reported a loose power jack. I took laptop apart. Reseated RAM, CPU and heatsink (replacing thermal compound with pad). I was able to get something on the screen once for about 30 seconds after unplugging and removing the adapter for several minutes. I am about to give up.
  • neik09 Jan 13, 2009
    I tried witout the battery, and just I plug the charger it's turn on but shuts off in about 5 minutes sometimes less than that. I need help I cleaned the fan and change the thermal compound. But nothing seems to work.
You need to remove and install the battery. Some times this works first try others may take a few trys. Mine does the same thing. Good luck
Posted on Dec 24, 2008
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
I am having a problem with a hp pavilion dv4. When it is plugged in the charging light will flash when i try to power it on the other lights on the case flicker and die . and if i plug in the laptop...
had a similar problem,and I resoleved it via a bios flash..this allowed the hardware to be fully recognized and to perform the specified role.For some reason,the bios software for this version seems to corrupt after several years. I have had my machine for the last four years..until it recently started giving the issues,it had no problems.
Jun 06, 2011 | HP Pavilion dv4000 Notebook
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
I have no power to my zv 5000(hp). It has the power cord and everything. the charge light does not light up when it chgs... But when I first plug it in I get a 3 second spurt of blue light from the on...
First of all, disconnect your battery from back of the
laptop, then try and get a friend or a technician that
uses the same type of laptop, and try to swap the
battery just to check whether it works and charges
it properly. Also do the same thing with the
Adapter/Charger and charge it with it.
This is because, there are two diagnostic possibilities
here:
1.) It is either the battery that you bought is not good
and you need to return it quickly before its too late
or;
2.) The charger that you are using is bad, or not
supplying enough current to charge the battery
cells...and this might even damage the battery after
a while, or make the battery not to charge to its full
capacity and as well discharge quickly.
Try this out and let me know how it goes.
Hope this helps you out.
Goodluck and thanks for using fixya.
Nov 10, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
When pluged into charger screen flashes on and OFF cannot get menu to come up
charger does not have enought power to charge the unit at a fast enought rate. Try a diff charger. one for a gps not a phone
Jul 02, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Laptop
please check first that does the notebook work fine on the battery mode.
if system does not work on battery mode also it is a fault of the board that would have to be replaced
if it works fine on battery, then the problem could be with the adapter
to check the same, please try using another adapter or the same adapter on another hp notebook.
if the adapter does not work on another notebook, please get the adapter replaced.
Jul 26, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
No power
Try purchasing an original adapter. I've had several machine of different make through my shop that the Targus adapter just simply won't run. For example, a Dell Inspiron 1100 and HP dv4000 won't run at all, and a Dell Latitude 1501 and Gateway crv503 will run but won't charge the battery. Targus adapters are junk, if you can, get your money back.
Jun 28, 2008 | HP Pavilion dv1000 Notebook
Ive reboot my laptap hp pavillion zv 5000 but sound doent work
i agree with exon33 as long as you are useing realtec you can do that anything else and you better off using the disks that came with it
Apr 21, 2008 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
541 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
