Question about Smart Solar Solar String Lights 20 LEDs with Butterflies by
I have two San Rafael solar Lantern but they are not coming on at night. I have let the batteries charge for three to four days and no results. Please help and I have them for two weeks. I can be reach at 770 969 0158. Thank you, Kathy
Do Solar powered lights work for outdoors?
yes
they have installed a small aa battery that is charged during the day by the solar panel and run until flat at night
Jun 15, 2017 | Solar Hardware & Accessories
How do i operate smart solar lights?
Place the solar panel in a sunny spot to charge the batteries. If the lights do not come on at night, the panel's light sensor may be seeing other light sources and needs to be moved. The light sensor looks like a small white circle with a wavy line across it. They are usually visible and located in the solar panel. Make sure it is in the dark at night, or it will not come on. You can cover the light sensor to test that the lights are working.
Jul 08, 2014 | Smart Solar Solar String Lights 20 LEDs...
What is solar camping gear?
Solarcamping gear is a great environmental solution that allows campers to use thenatural sun to power camping equipment instead of needing batteries foreverything. You can get solar spot lights, battery chargers, generators, andeven solar showers.
Aug 02, 2012 | Camping, Backpacking & Hiking
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
1990 c1500 silverado; Engaging the ignition switch results in one of four variables. 1. the engine fires right off and runs well. 2. dead silence 3. a single click 4. sluggish start akin to starting...
Check connections on the starter. If those are good you could have a starter relay going bad. If its not that check your body grounds under the hood and the ground from the engine to the frame. Hope its one of the easier solutions for you. Please rate if this helps. Thank you
Sep 13, 2010 | 1990 Chevrolet C1500
Protrek casio watche just stoped working
Is it SOLAR?
I have a Casio Pathfinder, SOLAR, ATOMIC! They have a permanent battery!!!
It must be exposed to the sun occasionally to charge. If yours has nothing on the display, try putting it out in the sun for a day. Put it in a window, sitting on a window sill. Depending on how little charge it has, it may take as long as three days to charge.
Otherwise, the alternative is calling Casio, getting an RMA and sending it to them for a battery replacement.
Aug 03, 2010 | Watches
Model 11-9305 trail cam only works one day after setup. takes good pics only for one event
The problem with the Bushnell Trail Sentry 11-9305 is that it is a power hog...I got this camera for Christmas 2009 and it had 2500 milliamp hour batteries with it and no solar panel...I have lots of coons and rabbits coming to the feeder and had up to 50 pics/night...The batteries would only last for three days or so...Since then I have ordered 10,000
milliamp/hr batteries and the appropriate solar panel that fits it...
When the batteries get low, the camera shuts off....
So, the problem may be that you had some bad batteries to start with..(Only takes one)
The first thing I would do is put heavy duty alkaline batteries in it...
(You'll have to reset the day and time)
If the alkaline batteries work for several days then do what I did...Get the solar panel that is made for it and HEAVY duty NiMH (Nickel Metal Hydride) rechargable batteries...(9000 or 10,000 milliampere hours)
You can buy these on E-Bay for about $26.00 for 4 batteries with free shipping...
Hope this helps !!!
Jan 23, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Smart Solar Solar String Lights 20 LEDs with Butterflies by Logo
300 people viewed this question
Top Smart Solar Home Experts
ArcFlash
Level 1 Expert
lakeareaserv
Tom Chichester
Are you a Smart Solar Home Expert? Answer questions, earn points and help others
