Question about Homelite Garden
We just purchased a Homelite Pressure Washer. We put new gas and oil into it, and it will run for about 2 minutes and then shut off. Now we can not even get it to run. We really don't want the hassle of returning it and getting another one. Can you please help with what might ever be the issue?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
A couple of things to check.. some rather obvious.
Assuming you have followed all the directions.. removed the pump vent plug before first use.. have a hose attached.. pressed the trigger on the wand to make sure you have water flowing etc.
Check to make sure the fuel valve is turned to ON.. fully..
If you Over filled the gas tank.. remove some of the petrol.. it should not be filled to the top...
Hopefully you put the correct amount and right type of oil into the crankcase.. again do not overfill the crankcase..
The fuel on most Homelite pressure washers is regular unleaded gasoline. NO E85 fuel should be used. Certainly no premixed gasoline for two cycle engines.
Check Choke position.. to start place in Cold Start or ON.. once started let it run for about 5 or ten seconds.. move it back to RUN..
If you ran it too long with the choke on you probably fouled the spark plug..
Remove it and clean it carefully.. if it is wet.. and all black.. it's fouled.. let it dry out.. clean it up properly (careful to not change the gap) replace and try again.
Lastly if you live in a neighborhood.. there is almost always a fellow nearby that is good with smalle engines.. ask around.. these guys are always happy to fiddle with these motors.
Best of luck to you!
Posted on Apr 10, 2011
Where to use pressure washer pump protector
If you're thinking antifreeze, it goes through water intake. Run until it comes out wand and shut down for witnter.
Sep 23, 2014 | Homelite Ut80993 Honda Gas Pressure Washer
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Where is the oil drain plug located on a Homelite 2700 psi 2.3 GPM Honda Gas Pressure Washer?
There is drain plug, surprisingly. You basically have to tip the washer over to the side opposite of the exhaust. I like to take the wheel off first. It is much easier this way. You don't want oil to get in the exhaust Or you could get something like a turkey baster and pull it out. There isnt much oil in there so it isn't that difficult.
Let me know if you need more assistance.
Travis
Jun 06, 2013 | Homelite Ut80993 Honda Gas Pressure Washer
Oil runs out under flywheel when motor starts honda GCV 160
Your top seal on the mower motor is faulty...replace with new seal...
Mar 25, 2013 | Homelite For Husky - Pressure Washer Pump...
Won't Stay On
If it's brand new, the first thing I'd check is the oil level in the Honda motor. Most pressure washers are tested then the oil is drained out for shipment. Honda motors have an oil sensor in them that will shut the motor off if the oil level is low. When the motor is off, all the oil is in the bottom of the crankcase and the sensor 'thinks' all's OK. When you start it up and the oil is getting splashed around it will get low enough for the sensor to shut the motor down. Also make sure the gas is turned on at the carburator.
Sep 04, 2012 | Homelite Pressure Washer. Honda 2700 psi...
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
Garden Logo
1,982 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
