Question about Brother EM-530 Typewriter
Is there a guide to put the paper in? ours seems to be missing.
  • Brother Master
  • 3,594 Answers
It should have a paper stand about 3" X 15" all the way across the typewriter and a adjustable L. paper guide on it. Google your model to get a picture.
DickyO
Posted on Apr 12, 2011
Radio code
miss?
lost? sure.
its lost because you never read the operators guide,
that is ok, nobody does..
the guide states, and i post in short. RTM.
1: day one, put code card in wallet or bedroom dresser.
2: day one if no card, get code from radio and mark the op guide
and put paper , in home, with same number.
3: if all the above was ignored then (in the book) take radio serial number to the dealer with proof of ownership of car (REG) and
get the secret number from the honda DB.
personally, my code will be at home, not in car, ever.
Sep 11, 2013 | 2003 Honda Odyssey
Tiny colored lines along left edge of paper
Spillage or bleed caused by color tint on paper guide path
You could try cleaning the guides or putting some blotting paper through the path to attempt to collect it. Otherwise it will need a service to determine why it is or has leaked.
Please rate our help to keep FREE service online++++Thanks for using FIXYA
Sep 14, 2009 | Konica Minolta magicolor 2300DL Laser...
Hi My Dell Laser 1815 is having a paper jam problem each time it tries to load the paper from the tray.
The paper tray itself is probably missing a small peice. Look towards the front of the tray... there is a guide (about 2" wide) that, if you push down, it springs back and forth. My tray was missing a small peice of flat metal that popped off. The feed roller rests on this piece when the tray is loaded. If the piece is missing, then the roller is to close and the paper cannot make it through into the printer. Still looking for the part number....
Sep 07, 2009 | Dell 1815dn All-In-One Laser Printer
Getting u6-00 on arc172 checked all conectors switched m/c off/on no joy
the error code is for paper miss feed or tray not set properly make sure you have the paper cassette is put in properly and that the paper guide plates at the sides of the paper are set properly and the guide at the back is holding paper in tray correctly o-pen the paper tray take it out and check this and then reset open the side door and close it correctly and this should help reset youcan check the paper feed rollers as well as sometimes they get dirty and will not feed properly you can clean these with a little glass cleaner and a soft cloth good luck A
Jun 28, 2009 | Sharp Office Equipment & Supplies
Both our brand new copy machines SHARP M316 have problem with the
first thsing to check is the side guides for the paper make sure they are set against the paper being fed through if not the paper will be pulled through at an angle and this can cause your problem you can alson get a slightly heavier paper and put that through to see if you have a jam..did you remove all the packing tags and paper protectors
Jun 15, 2009 | Office Equipment & Supplies
- "No cassette with paper of size requested ...
One of the cassettes is usually universal, if they tray has moving edge guides, the put in the paper you need and adjust the guides.
If the paper needed is in the cassette and you still get the message then the document feeder sensors are miss reading your original size, thy cleaning out the document feeder with a vacuum or compressed air, especially around the paper sensors..
Hope this is of some help
Ed
May 26, 2009 | Toshiba e-Studio163 Copier
The legal size tray seems to be too short.
you didn't give a model number, but all HP's I have dealt with have a slide out paper guide to hold the paper. I suspect yours is missing or broken.
Mar 27, 2009 | HP Office Equipment & Supplies
How do you change the paper selection?!?
if you have a different size/type paper in trays, just choose auto tray from printing preference, you only have to put right paper type /plain/thick ..... and the printer find it self the right tray
Oct 28, 2008 | Konica Minolta bizhub C250 All-In-One...
Brother EM-530 Typewriter Logo
27 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
