Question about Phoenix Grill Company 124 Tamiya Model Opel Astra V8 Coupe Phoenix 24265
I have a opel astra 1.6 h 2005 after switching off the radio , it comes back on itself , I parl the car switch all off after 15minutes the centre interior light comes on the Radio comes on ect so I switch it off again by itself 15-20 minutes later radio comes on , even when driving I switcj off the radio but after 15 minutes it comes on any ideas why m and how to fix please
  • ruel452
    ruel452 Jun 15, 2012
    I have a simmilar problem can any one help.
Car off battery drops to zero if connected
excessive current being drawn when key is out and battery in ,check rear boot light radio wiper return switch and security system.or tracker. coloneus
Feb 26, 2016 | 2001 Opel Astra
I have a 2000 opel astra,serviced starter ,fitted again,now car start but switch off again,and then wont start immidiate again,please help
Sounds like the wires may not be hooked correctly on the starter; maybe one was left off. Or you may have blown the fuseable link in the cable. Check all the connections to verify they are correct, then verify there is power reaching the starter to verify the fuseable link isn't blown.
Mar 28, 2014 | 2000 Opel Astra
Opel corsa 1.6 Sport 2005 model. When driving 120 km/h the car runs at 3700rpm. Is this normal or is it to high and if it is how can this be fixed? your assistance is highly appreciated!
I have a Opel Astra 1.6 2005 , when I switch off the car , switch off the radio the power or radio comes on by itself , the dash lights up the cabin light comes on including the radio , then i switch it off 20 minutes later all comes on by them selves leaving me with a flat battery in the morning , while driving I drive switch off the radio then 15 minutes later radio comes on by itself why anyone know how to fix
Thanks kelly
Oct 28, 2010 | Chevrolet Corsica Cars & Trucks
Put new bulbs in my 94 cavalier and changed flasher but the still won't work
check out the hazard warning switch,cavalier is the same as opel astra ,then its same as my car with a vauxhall badge?? hazard switch on dash in middle above radio ,they play up something cronic if used too much either lights stay on or dont work at all
Mar 05, 2009 | 1994 Chevrolet Cavalier
Opel Astra G 2002 Radio Set from Japan to Middle east
simply your scanner range is from 77 to 90 mhz. you can not listen to any higher frequencies than that.
Nov 03, 2008 | Radio Communications
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
Phoenix Grill Company 124 Tamiya Model Opel Astra V8 Coupe Phoenix 24265 Logo
75 people viewed this question
Top Phoenix Grill Company Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Phoenix Grill Company Toy Expert? Answer questions, earn points and help others
