Question about Hotpoint Aquarius WMA42 Front Load Washer
Water will not pump out - lights then flash for non crease and mini load and the on/off switch keeps flashing - drum going around ok but not draining the water?
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Please score this solution accordingly- thanks!
Posted on Apr 10, 2011
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Hi my hotpoint wf541 will not run the start stop light and the mini load light are flashing i believe these are fault codes but have no refrences to what they are
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Apr 04, 2009 | Washing Machines
Reduce crease and mini load lights flashing on hotpoint wf541g. had pump failier and have replace with new on but still not pumping water out.
  • On/Off.
  • Reduced creases.
  • Mini Load.
Mar 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing machine will not finish cycle and the reduced creases and the mini load buttons continuesly flash. Do you know how to solve this problem? My problem is same as earlier person identified sep 08. I...
Could be pressure switch jammed on empty, check pump for draining properly..
Select drain only and see if the water comes at a good rate, there are other problems that could the sequence of lights flashing that you are experiencing.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hot point wf541. have top 2 lights on wont pump
Hi.
The sequence of flashing lights is in fact indicating an error condition on your m/c.
It indicates that the m/c has failed to drain, possibly because the pump filter is blocked.
Your m/c is fitted with a filter system for the pump,
The filter may have become blocked, see care and maintenance in your handbook, in your handbook for details on how to check and clean the filter.
Also make sure the door is shut properly.
If after you have checked all these points, and it still does not work properly, then I suggest you have someone to look at the m/c, or replace the pump if it does not appear to be working.
Hope this helps.
Please leave feedback.
thanks.
Nov 30, 2008 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
