Question about XFX GeForce 6200TC Graphic Card
One of electronic elements is cracked, and there is red dirt on it. Video card is working, but when I setup driver on Ubuntu 10.4 it starts freezing. So I would like to know if it something wrong with drivers, or with my video card.
  • 11,800 Answers
Not a driver problem - that red dust is oxides from the components of the capacitor. Without that part the video card works only at the most basic level. Try to replace it or the card is dead.
Posted on Apr 13, 2011
Testimonial: "Thank you very much!"
I have installed a Geforce 210 pcie card on my pc. After I install ubuntu 16.4.1 I get a blank screen with a red box in upper left corner. cant do anything else. Works fine with my older card
Download and burn recovery cd that boots into memory and not install.from here
https://www.system-rescue-cd.org/Download
when booted from it try finding correct video driver for Ubuntu or un install video driver and reboot
Nov 30, 2016 | Computers & Internet
My VGA has been corrupted. How can I fix it?
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust ,
If supported you can run a LINUX disk like Ubuntu in live / try mode
If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue ,
but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault
If a likely software issue then uninstall and then reinstall the video card
Consult ASUS or Nvidia support
The procedure is something like this
Onboard video support ?
yes
uninstall the video card driver and any video vendor configuration applets
Uninstall video card in device manager if still present.
Shut down and remove mains power cable
remove the hardware video card ,
(using anti static electricity procedures)
Attach onboard video to display
Power up and enter and configure BIOS setup if required, ie 1st seek onboard video
Bootup to Windows
Install the onboard video device
using Windows plug&play default driver executed during booting
Restart
Confirm working ok
Update the chipset driver (inf) if applicable,
restart
Shutdown
Reinstall the hardware video card
Attach to display
Reconfig BIOS setup if required
Start to install default driver
Install video driver / update from card default using a known good driver whose setup file has been previously downloaded
restart and test
Hope this helps
Dec 06, 2013 | ASUS GeForce Computers & Internet
Scaleo p fitted new graphics card asus geforce 210 wont start up
Hi , i suggest try running the driver setup in "custom mode" checking option : clean install , to remove previous possibly corrupt installed settings
Also access BIOS setup and change "first seek peg" or some such, so BIOS communicates to Windows to first seek video device expansion card rather than onboard
(ps , if changed from onboard to expansion card ensure the onboard control applet for onboard video has been uninstalled via add/remove)
Jan 26, 2013 | ASUS GeForce 210 Silent - 512 MB GDDR3 -...
I need Adobe Photoshop Elements 10 Serial Key
need a serial number for adobe elements 10
Nov 05, 2011 | Computers & Internet
How install driver delta66 in Ubuntu ?
The Delta 66 uses the Envy 24 chip which is recognized by the ALSA driver in most Linux distros including Ubuntu automatically. There's no driver to install, because it's already in the the ALSA driver. Open up the ALSA mixer setup your output settings and you're good to go.
Sep 25, 2010 | M-Audio Delta 66 Sound Card
Game is loaded start program opens up and then freezes
have you updated all your video drivers? if not try that, it may work
Apr 13, 2009 | EA - Electronic Arts Command and Conquer:...
Need a solution to get Ubuntu to work with this video card
ATI cards are always a bit of an issue with Ubuntu - ATI offer very little support, in contrast nVidia are very impressive.
There seems to be a lot of issues with ATIs and Jaunty so you're probably best to stick with Intrepid (8.10).
Look into fglrx.
Apr 12, 2009 | ATI FireMV 2400, (128 MB) PCI Graphic Card
HD 3450 ubuntu driver
Install the package xorg-driver-fglrx. You can get it from http://packages.ubuntu.com. If you experience any problems then try this link: http://ubuntuforums.org/showthread.php?t=926860
Oct 31, 2008 | ATI RADEON Graphic Card
Configuring Webcam andPrinter in Ubuntu
Normal 0 Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jul 23, 2008 | Computers & Internet
XFX GeForce 6200TC Graphic Card Logo
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
