I have an old dehumidifier, it is an ebco oasis, model sd- 32. when i turn it to "stay on" it kicks on for 5 secs or so then kicks off then in a minute or two kicks on for 5 secs and so on and so on
    Scholar:
  • 133 Answers
It is probably equipped with a low pressure switch. If so, that is exactly what it would do if low on refrigerant.
Posted on Apr 10, 2011
My Kenmore dehumidifier fan runs all the time & compressor kicks in & out. I the fan supposed to run continually.
yes if its less than two years old the new ones run the fan all the time and cycle the compressor off humidity of room , the fans even have speeds on some models so you can turn em down
Nov 08, 2014 | Dehumidifiers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Danby 25pt dehumidifier not collecting water, fan is working can hear the compressor kicking in, is almost 5 years old though, is it time for a new one?
Christina, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this will help you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 18, 2011 | Danby DDR586R Dehumidifier
The compreesor only stays on for a few seconds then kicks off. how do I set it so it will stay on
Dave, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
level
problem.
Hope this helped you to troubleshoot & sole the problem.
Jul 20, 2011 | Danby DDR5009EE Dehumidifier
The dehumidifier does not collect any water, the fan is running and I can hear the compressor kick on and briefly run 10-15 seconds, The fan runs continuously.
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled model, set the humidity extraction level on Maximum.
level
problem.
I hope this helps you to troubleshoot and solve the problem.
Jul 08, 2011 | Maytag M7DH45B2A Dehumidifier
Haier hd656e, my dehumidifier runs about 30 sec and turns off,
This sounds like a main circuit board problem and is very common with many dehumidifiers... They can be replaced on some units. You can do a search online for the part easily...to see if it is available.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 16, 2010 | Haier HD656E Dehumidifier
Dehumidifier model M7DH65b 2A
Its too old where you are running the appliance - lift it up in the air or raise the heat in the room. This is *not* a low-temp dehumidifier.
Jun 09, 2008 | Maytag M7DH65B2A Dehumidifier
Whirlpool AD50USR1
Sounds like a problem with the compressor. Should be covered by warranty is it is defective.
May 01, 2008 | Dehumidifiers
Won't shut off
Sounds to me like the hemostat is sticking or our of calibration, unfortunately it would have to be replaced to fix this problem
Jan 21, 2008 | Oasis Industrial Strength Dehumidifier
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
