Question about Mantis 2-Cycle Tiller
The engine turns over but then stops after a few mins and the blades are not turning fast. What is wrong?
Washer/dryer on spin fast but keeps stopping and starting how do I open the door?
If you sure that its not full of water, you should set the program to the stop position, and wait a few mins for the lock to release.
Jun 04, 2016 | Washing Machines
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
After replacing i cranked the truck and the steering wheel took off very fast turning by its self from left to right back andforth until i turned the truck off . what is wrong.
Did you bleed the air out of the system? Try that first. Just turn the wheel from left stop to right stop a few times with the engine running.. Then check fluid level and add as necessary. Repeat turning the wheel a few more times until the air is out of the system
Mar 04, 2015 | Cars & Trucks
Why Does the blade stop upon contact with material
Few factors to check: Blade Tension- always put appropriate tension on the blade. Second, Blade Problem- you're problem using the wrong tpi or the blade itself is bad. Third, you are running the blade too fast or you're overfeeding the stock. Make sure that you let the blade do the cut. I suggest you read blogs about blade break in procedure. I am using Haltbar band saw blade from sawblade.com. I never had a problem with their blades.
Oct 10, 2014 | Saws
Craftsman gt 5000 blades quit turning
is there a wiring rubbing on metal?is a safety switch failing?
Apr 16, 2012 | Craftsman Garden
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
I hit a rock and the mower engine stopped. Idisengaged the blades and restarted the mower and drove it over into the shade to nvestigage later. When aicame bqack several hours latter, the engine would not...
I think i know what is wrong ,its kind of strange that everything went bad just then,but if you were at full trottle when you hit that rock and it stalled the motoryou might have more damage then you think to find out take the spark plugs out and turn engine over if it turn quite fast with no problem then there shouldn't be anything wrong with the starter/battery you may have sheared the that keed the timing set to top dead center then you need to take it to the repair shop
Apr 11, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The blade spinng fast and not pulling trigger
The idle speed screw (not the idle jet screw) is set too high. Turn it CCW while running until the chain stops turning, yet the engine keeps running. Hope this helps!
Apr 19, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Wiper does not stop wiping until engine shut-off
you need to replace multi function switch
May 08, 2009 | 2001 Oldsmobile Intrigue
Mantis 2-Cycle Tiller Logo
24 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
