Question about Mitsubishi VS-45607 45" Rear Projection Television
Vs-45607 I have the same problem, but it take about 48 hours for the picture to stop rolling if the solution is the same is there a manual, or schematics on this model. This tv was manufactured in 2000 . Thanks for your time. [email protected]
  • 927 Answers
Good Day, chefkenny;
This the fix ya you are looking for;
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Good Luck, big IRISH.
Posted on Aug 07, 2008
SOURCE:
Mitsubishi Vs-60705 Bigscreen turn on vertical roll warms up stops rolling and begins jumping up and down also picture is not clear
Check C2P05[ location on convergence board]. This is a 16volt 100Mf cap that is bad. And check out C2V29 [cap value is 16volt 22 Mf.] And still while you're at it, resolder the pins on the convergence ICs.Should fix your TV!
Nov 29, 2009 | Televison & Video
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi mod. vs-5072 rolls how fix?
check for swollen capacitors- bad capacitors will cause the screen to roll. If the top of a capacitor even looks SLIGHTLY puffed up, replace it!
Dec 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Good Day, skieebumm;
There no adjustment. Try this: (MENU DOES NOT ROLL) CHECK C2A04, 10 UFD 50V OFF PIN 5 OF IC2A01 ON THE VIDEO PCB. 2. CHECK C2046, 47 UFD @ 50V OFF OF DL2001 ON THE VIDEO PCB. 3. (MENU DOES ROLL) CHECK C2B14 10 UFD @ 50 V NP OFF THE BASE OF Q2B02 ON THE VIDEO PCB. Good Luck, big IRISH.
Sep 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
The picture rolls vertically sometimes.
I would check the capacitors in the verticle deflection circuit. Also try resoldering the verticle output as well as the verticle yoke pins where they connect to the chassis. Mitsubishi has had some trouble with their capacitors, you may have one that is leaking. Let me know if I can help you further.
Jan 13, 2008 | Mitsubishi VS-60801 60" Rear Projection...
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
