Question about KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher
CHANGE COLOR OF KITCHEN AID DISHWASHER - KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher
    Champion:
  • 246 Answers
Go to www.applianceart.com
They have many options available for changing the color of your Kitchen Aid dishwasher. They also have designs, textures and stainless steel.
Posted on Sep 07, 2011
Kitchen aid KUDM01TJWH0 dishwasher- stopped mid-cycle, normal and rinse buttons are flashing.
I have same problem. I can't find the Troubleshooting diagnostic instructions. These are usually hidden somewhere on the washer. Do you know where they are?
Apr 26, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
Looking to change the color on my kitchen aid dishwasher to black front panel can this part be ordered.?
Typically yes. Just contact Kiitchen Aid or a dealer and they should be able to help you. Depending on the model, they also make kits to accept wood panels to match your cabinets.
Oct 18, 2010 | KitchenAid Dishwashers
Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Logo
226 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
