Question about Specialized CrossTrail
When I takemy front tire off I cant get it back on as my disc brake will not go into the groove? How do I loosen the groove for th edisc to fit in? I have a specialized crosstrail 2010.
  • 31 Answers
The only loosening mechanism should be the quick release, you should have your bike upside down, and place the wheel aligned into the shocks before you insert the quick release pin and nut.
Posted on Apr 12, 2011
How do I replace the front disc brake pads
Take tire off, loosen 0ne screw at bottom of caliper, which holds the brake pad, take other one out, swing caliper out, r and r brake pads, push the 2 round black pistons back down, (c-clamp does this good), then push caliper how you found it, tighten screws, put tire back on, bleed brakesto get air out, should be good to go.
Sep 26, 2014 | 2004 GMC Envoy
How to remove front tire 1996 chevy cavalier it has grooves that hold it onto the hub.
The wheel is not attached to the hub, it is actually stuck to the front of the disc brake rotor.
And it is probably rust that is holding it fast.
Rap the wheel lightly with a hammer between each of the lug nuts to help break the rust behind it that is hold it in place. You can also try squirting some PB Blaster or other screw looseing lubricant on each of the lug nuts so it can soak in behind them.
Heat cycling (applying a propane torch to the metal to heat it quickly, then taking it away so it cools quickly) can also help loosen the rust.
Brute force is the final step. Kick the tires - literally. WIth the corner of the car jacked up, kick the side of the tire at the TOP - hard. Try kicking the side of the tire at the BOTTOM too. DO NOT KICK THE side of the tire at the front or back though - this puts excessive stress on the steering linkage and can bend / break things.
Getting the tire loose will involved doing these things, perhaps multiple times, until it finally comes loose.
Apr 24, 2014 | Wheels, Tires & Parts for Chevrolet...
Cant get front tire back on 2011 yamaha ttr 125 le motorcycle how to loosen front break pads to put tire back on
Hi, great bike! take two flat blade screwdrivers; place 1 on top of pads, in between the pads,and the other opposite the first screwdriver then gently flex the screwdrivers sideways. You are squeezing the brake fluid back into the master cylinder on the handlebar. do it gently. you should now have enough room to slide the disc back into place and put the axle in. Happy riding.
Mar 12, 2014 | 2003 Yamaha TT-R 125 LE
Change disc front breaks 2001 seville
jack up the car and remove the tire. you will see a caliper that is the thing that looks like it is hugging the disc. there are 2 bolts on the back side of the caliper. one on top one on bottom. loosen them and then they slide back out of the way. the caliper will then slide off. remove the old brake pads. use a 4 inch C clamp with the threaded end inserted to the cup part of the caliper and the stationary part on the opposite side and tighten the clamp down slowly. this will open the caliper back up so it will fit over the new brake pads. after you have the new pads in place slide the caliper over the brakes and disc realign the bolts that hold the caliper in place, tighten, replace tire and repeat on the other side. once complete make sure you pump the brakes a few times be fore you move the car so the caliper can close in on the new brakes otherwise you won't have any brakes for the first few pumps of the pedal
Jul 14, 2012 | 2001 Cadillac Seville
How do you replace the front brake caliber on a 1997 ford expedition
Caliper Removal
  1. svj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut . Heat can damage the wheel and the wheel bearings.
    Loosen the lug nuts.
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
      1. svj~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE ELECTRICAL POWER TO THE AIR SUSPENSION SYSTEM MUST BE SHUT OFF PRIOR TO HOISTING, JACKING OR TOWING AN AIR SUSPENSION VEHICLE. THIS CAN BE ACCOMPLISHED BY TURNING OFF THE AIR SUSPENSION SWITCH LOCATED IN THE RH KICK PANEL AREA. FAILURE TO DO SO MAY RESULT IN UNEXPECTED INFLATION OR DEFLATION OF THE AIR SPRINGS WHICH MAY RESULT IN SHIFTING OF THE VEHICLE DURING THESE OPERATIONS.
        Raise and support the vehicle.
      1. Remove the wheel and tire assembly.
        1. Remove the lug nuts.
      2. CAUTION: Replace the lining if worn to or past specifications. Replace the brake shoes and linings in complete axle sets. Inspect the brake shoes and linings for wear or contamination.
      3. svj~us~en~file=ani_caut.gif~gen~ref.gif WARNING: BRAKE FLUID CONTAINS POLYGLYCOL ETHERS AND POLYGLYCOLS. AVOID CONTACT WITH EYES. WASH HANDS THOROUGHLY AFTER HANDLING. IF BRAKE FLUID CONTACTS EYES, FLUSH EYES WITH RUNNING WATER FOR 15 MINUTES. GET MEDICAL ATTENTION IF IRRITATION PERSISTS. IF TAKEN INTERNALLY, DRINK WATER AND INDUCE VOMITING. GET MEDICAL ATTENTION IMMEDIATELY.
        Disconnect the front brake hose (2078).
        1. Remove the front brake hose bolt.
        1. Remove the copper washers. Plug the front brake hose.
        1. Disconnect the front brake hose
      4. Remove the disc brake caliper (2B120).
        1. Remove the two caliper bolts.
        1. Lift the front disc brake caliper (2B121) off the front disc brake caliper anchor plate.
      5. On 4x2 vehicles, measure the front disc brake hub and rotor (1102) thickness.
        • Replace the front disc brake hub and rotor if not within specifications 27.7mm Min.
      6. On 4x4 vehicles, measure the front disc brake rotor thickness.
        • Replace thhe front disc brake rotor if not within specifications. 27.7mm Min.
      7. Inspect the disc brake caliper for leaks.
        • If leaks are found, disassembly is required
Mar 10, 2010 | 1997 Ford Expedition
How to change front brake pads
the brake caliper pistons need to be pressed in with one of the old pads before installing the new ones.
Sep 14, 2009 | 2003 Yamaha TT-R 125 LE
ReAssemble front wheel . Can't get front wheel over the brake pads of the bicycle
need to loosen the cable so the brake will spread apart
Jul 31, 2009 | Cycling
Skweeking brakes
Several possible causes:
  1. Did you use copper-based brake grease on the brake pins and the back of the pads?
  2. Did you clean all the old gunk off the brake pins and after doing so, where they deeply grooved? If so, you must replace them.
  3. Wrong brake pads. Some pad manufacturers list a patricular pad as being OK for a vehicle. They fit OK but the pad characteristics are wrong and they squeal like crazy or wear out in no time or give lousy raking performance etc.
  4. If the pads you removed had anti-squeal shims on the back of them did the new ones? They almost certainly should have. IIRC, they are held to the pads by some double-sided adhesive tape.
  5. If you get squeak-silence-squeak-silence... at low speed (i.e. just before coming to a halt) then the disk(s) is/are distorted. They will have to be replaced. You must not machine the discs on these brakes - there is no thickness available to do that. If you do tthey may well collapse under the heavy braking of an emergency stop with very unfortunate consequences!
  6. As someone said, the disc may be badly worn and/or grooved -check and replace if necessary.
  7. You may have a stone or piece of grit stuck between a pad and a disc. If so & it's worn a groove in the disc,you will need to replace both disc and pad.
  8. Make sure you torqued any brake bolts correctly and that you put thread sealant on them. Failure to do so can lead to them loosening in normal use. The brakes may squeak for a while if this happens but then things can get much worse...
Sep 18, 2008 | 1995 Volvo 850
Specialized CrossTrail Logo
156 people viewed this question
Top Specialized Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
richie46
dante
Are you a Specialized Cycling Expert? Answer questions, earn points and help others
