Question about Whirlpool Washing Machines
I have the duet ht and when I fill the soap and fabric softener dispenser at the beginning of the load they both run out. Shouldn't the fabric softener be released with the rinse cycle?
    Genius:
  • 1,028 Answers
Pull drawer completely out by pressing release tab on left rear of drawer remove all the cups and clean thoroughly with damp rag wipe upper portion on opening before reinstalling drawer
Posted on Aug 07, 2008
My soap dispenser does not clean out. ie fabric softener compartment does not rinse all of the fabric solution out.
Hi, remove the dispenser draw and clean out, you'll probably find a load of unused soap and softener gunked up in it
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The soap dispenser works but the bleach and softener dispensers do not
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking soap dispenser
There should not be suds up that high in the washer. You are experiencing a over sudsing condition and spin is throwing up throw the fill line in the dispenser. Run some fabric softener in a load with no clothes to clean out any hidden suds. Then use only HE (High efficiency) detergent and half of what they recommend! The softer the water the less the soap you use. Sounds like you may be using non HE detergent. My guess if the machine is fine.
Jun 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Put fabric softener in the soap dispenser
Just run the load. You can always re-wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Kenmore Washing Machines
Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Fabric softener dispensing before wash begins
I was having the same problem. Repair man replaced VALVE AW
He told me it is from the sedement in your water. If you have a water softner, it may not be the problem, unless it is not working properly. Sounds strange, but problem is fixed.
Nov 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Detergent and fabric softener dispense at the same time
Whirlpool has designed this drawer as a siphon feed and soap and softener go as 1, 2 punch followed by bleach mid cycle.
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener leaks out at beginning of wash
I have a 9200SQ Whirlpool duet.  It might be similar.  I think the bleach and fabric dispensers work on the siphon principal--once the level gets above a certain point they will then siphon out until almost nothing is left.  They should not start to siphon until extra water is directed into them during the correct cycle.   It is possible that they are starting to siphon early because 1. the washer is not level, 2. water is being added to the dispenser during the wrong cycle 3.  You put too much liquid into the dispenser and it started the siphon.
Note:  You should not peek in the dispenser during the washer cycles because it might interrupt the "siphon"action and leave residual bleach or fabric softener in the dispensers.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
155 people viewed this question
Dan Webster
Dan Webster
Sal De
