Question about RTO Bernzomatic Brushed Nickel Patio Heater
It will light but goes out after 3-5 minutes. Tank is full and there was no wind.
  • 310 Answers
Chances are that it is the thermocouple. Ive seen many on their way to going bad that held the pilot valve open so it kept the pilot lit, but after a couple minutes of burning, the vent gases pull the flame away from the thermocouple just long enough for it to quit. You could replace it , or try to adjust the pilot flame orifice in the direction of the thermocouple so that it has better contact with the thermocouple.
Posted on Apr 12, 2011
Loses pressure after a couple minutes
do u hear any leaks wn its at full pressure from hose or connections. a lite soapy solution sprayed on connections will find leaks UNPLUG FIRST! also listen 2 compresser head 4 reed valve leak . Poss air cleaner dirty
Apr 28, 2012 | Simer 2802E Shallow Well Jet Pump & Tank,...
Hi there. My mower runs like a charm for the final 2-3 minutes before it runs out of gas. When the tank is full, the mower goes from full power to very low power to full power to very low power every 2...
Sounds like you need a new diaphragm kit which goes between the fuel tank and the carburetor. I just found out that they actually sell these at Lowe's now: Item #: 21969. Replacement of this kit is better left to a professional, if you're not sure what you're doing. But if you're able to do it yourself, it will set you back a whole $3 USD. Best of luck.
James
Sep 02, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
2004 malibu start engine and gas gauage goes to full with a full tank of gas after 1 minute it goes to empty. also does it when tank hyas any amount of gas. please help
unfortunately the fuel gauge sender will need replaced, I've done hundreds. the fuel tank will have to be removed as it is located inside of the tank, this is a very common problem
Aug 25, 2011 | 2004 Chevrolet Malibu
My propane tank is full, but none of my 3 burners come on, 1 does very slightly but then goes out, help! thanks
Turn the propane tank valve to OFF. Disconnect the hose from the tank and wait 5 minutes. Then, reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the tank first and turn the burner knob to high. Does the flame height look as it should? I f it does, light the remaining burners the same way, one at a time. Do all the burners burn as they should? If so, you solved the problem. If not, you need to replace the grill hose/regulator assembly. You can get one from any home center or hardware store that sells gas grills and accessories. Just take your old one with you for comparison purposes.
Hope this helps and Happy Grilling!
Apr 10, 2011 | Brinkmann Charmglow Stainless Steel LP...
2001 Olds Silhouette: plenty of gas in the tank but the gage will read full, 3/4 full, 1/2 full, and everywhere in between. Van runs fine. No other issues except the gage goes crazy and can't depend on...
2000 Olds Silhouette: plenty of gas in the tank but the gage will read full, 3/4 full, 1/2 full, and everywhere in between. Van runs fine. No other issues except the gage goes crazy and can't depend on what it says. ...
Aug 12, 2010 | 2000 Oldsmobile Silhouette
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working...
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Mar 22, 2010 | Weber Q Grill
Gas gauge - Doodge Caravan 2000
Probably easier to replace fuel tank sender unit as constant on off condition heard or not cant be good .Potential electrical spike.
Feb 15, 2009 | 2000 Dodge Caravan
1999 lincoln washer light stays on battery light goes on and off
disconnect the battery for 10 seconds but you might need the code for the radio after you disconnect the battery.
Dec 18, 2008 | 1999 Lincoln Town Car
Amana APO95R Turning Off/Tank Light (!) On and Off
There are only two items that will shut it down after it is set to run. The bucket full which you took care of and low humidity in the area it is being operated in. Low humidity would not constitute a reason for returning it.
Jun 15, 2008 | Amana Haier AP095R Air Conditioner
RTO Bernzomatic Brushed Nickel Patio Heater Logo
265 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
