Question about Refrigerators
Our Crystal Cold Propane refrigerator keeps defrosting and will not keep contents cold even tho the burner is on. the flame sensor will not move to green.
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
Master_Tech
  • 770 Answers
SOURCE: Refrigerator not cold enough
check the back wall of your freezer for a heavy frost build up rhis is an indication of a defrost problem also make sure the fan in the freezer is working
Posted on May 11, 2008
CRTN
  • 716 Answers
SOURCE: GE Side by Side GSS22JERFWW not keeping cold
often there is a cover in the rear of the freezer with some screws remove these and put low temp grease on the fan. The Problem Is %100 The Fan So If You Look Up Your Fridge On Google It Will Tell You Where The Fan Is.
Posted on Jan 05, 2009
whytfang
  • 170 Answers
SOURCE: freezer is cold but refrigerator isn't
Number one when you can always provide model number and make...it helps enormously in troubleshooting otherwise you get these long detailed threads...from an anal tech like myself.
Cold is a relative term....how cold...use a thermometer...and determine if the freezer...is at least..10-20 degrees or colder if not it is not cold enough...and here are some generic answers for that problem....I will list at the bottom of this thread...if it is
A. You will need to determine if you are getting air flow into the refrigerator side compartment..there is usually a baffle...that controls...the amount of air-flow into the frig side...it can be adjusted...if not it could be broken or have come loose...it is rare...
B. Is something blocking the baffle...as in food ...groceries...
C. The thermostat could be out of adjustment...and or going bad...(how old is the frig)..
D. Some newer units have a dual fan system..(but rare)..if the frig side fan is out...this could be the problem...
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer and hold the button in above the door..(fan switch)...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Apr 22, 2009
voodoomox
  • 1689 Answers
SOURCE: I have a Crystal Cold
hi mmpdk
thanks for using fixya.
this has go to be the thermal fuse or the capacitor for the thermostat assembly. These part control whether the unit gets cold or not and sustain the chose temperature.
the parts mentioned abive is usually located in the background near the thermostat controller or the power supply, near the heater assembly away from the blue flame.
these part replacements can be done through DIY, but best if you bring it to a service center.
hope this helps.
regards,
voodoo
Posted on Jun 14, 2009
I have a new Crystal Cold 18 Cu. It keeps shutting down. How long should it be at maximum before I turn it to a medium cold ? I have a 1 inch exhaust linked to the chimney venting outside.Pierre
It has to be absolutely level to prevent damage. Place the level in the freezer compartment and adjust the leveler feet to get it level. Once that is done, put a thermometer in the freezer and watch how long it takes to freeze ice. Now about that vent . How long is the pipe? If it is too long, it won't vent properly and the hi heat sensor in the flame compartment will shut it down for safety.
Aug 11, 2016 | Crystal Cold Stainless Steel Propane...
HREEZER WORKS ON PROPANE BUT FRIDGE DOES NOT
You more then likely have a weak flame. Most of the time this is caused by a dirty orifice. It is located just before the burner. You must first remove the burner cover, then you will see it. It is the brass piece that the propane shoots through before entering the burner. You can unscrew the orifice from the gas valve assembly. Then soak it in rubbing alcohol for an hour or so. Blow it out with air and re install it. DO NOT POKE ANYTHING THROUGH IT! This should fix your problem. ArctiCold Refrigeration We keep it cold or Store a4efa292-1c08-40ca-a993-9395db1be4a3.jpg
Mar 28, 2014 | Dometic RM2652 Refrigerator
I have a Crystal Cold propane refrigerator and
You more then likely need a new thermostat. b0560f71-786e-45e7-a413-9112b90c0a0f.jpg
Sep 14, 2013 | Dometic RM2452 Refrigerator
Does the 2652 constantly burn LPG when in gas mode. For some reason (probably told so erroneously?) I was under the impression that the fridge automatically switches off and on the LPG flow/ignited as it...
The RM2652 should shut down when the fridge reaches proper temperature. So yes the flame should go out when operating on propane. If the refrigerator does not get cold enough, then the flame will not ever shut down. It is posible that you may require a replacement cooling unit. WEB SITE: ArctiCold Refrigeration We keep it cold
ONLINE STORE: http://www.rvfridgerepair.com/ 0d79856c-1b32-4d85-a920-5d4fdb51f083.jpg
Aug 03, 2013 | Dometic RM2652 Refrigerator
I have a Kenmore upright freezer model number 253.9287413 manufactured '00 which has been a real champ. It's gotten a little 'flakey' the past month. Side are VERY hot, occasional water...
if you had to defrost a no frost unit the guess what you have a defrost problem. . i would thaw it out and replace the terminator on top of the cold coil . also ck the heater and replace if bad. .. if needed then replace the defrost control. ( adc) .. this will correct most problem with the ice problem .. mm .. mm
Jul 10, 2011 | Refrigerators
Freezer is not cold enough to make ice and all the contents are dethawing. Fridge is also not cold enough to keep things as cool as they should be
Seems like a defrost problem. Pull back panel and check frost pattern, if completely frosted,Turn the defrost timer (behind the kick panel in front, or mounted on the back panel) till the fridge goes into defrost. If defrost heater now gets red, replace the defrost timer, if not remove the defrost thermostat clipped to the evaporator coil, and check for continuity while still cold.
Jul 07, 2011 | Kenmore 50522 / 50524 Side by Side...
Our Crystal Cold propane refrig freezer unit keeps everything frozen but the refrig portion isn't keeping things cold and we've had to throw out a bunch of food. Any suggestions on what the problem could...
I am working on similar problem on my Crystal Cold refrigerator. I've found the seal between the  main door and the refrigerator body is starting to gap. We've also recently noted a few small flies in the frig. To diagnose, I took a butter knife and gently tested small gaps in the seal and found the ones on the lower left of the door (facing the frig) went all the way through. I'm on line now looking for a good price on new seals. They may be as much as $100. I may, if I can't get a better deal try some foam rubber window seals, the kind that comes in small rolls.
Aug 19, 2009 | Refrigerators
I have a Crystal Cold 18 cu/ft propane refrigerator/freezer. I've had this unit for 7 years now and I clean the burner and the flue on regular intervals. After this last cleaning the unit would not stay...
hi mmpdk
hope this helps.
regards,
voodoo
Jun 14, 2009 | Refrigerators
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Flame not hot
If the propane tank is full, it could be the pressure regulator. Some regulators have an adjustment screw on the top.
If it's REALLY cold outside, the propane may not be evaporating fast enough to keep the pressure up. Also on a cold or windy day, heat is drawn away from the grill very quickly, and it may be difficult to keep the temperature up inside.
(And Happy Grilling!)
Mar 31, 2008 | Vermont Casting The Extreme VCS5005BI...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
