Question about GE GSS22SGM Side by Side Refrigerator
GSS22SGMC BC is working on and on. Does not shut down. Everything get frozen in refrigerator on low settings.
SOURCE: Fridge works only on the max setting
needs a defrost heater, keeps it from freezing up. my friends did the same thing, she changed defrost heater and works fine now.
Posted on Oct 29, 2008
SOURCE: refrigerator side freezes even on lowest setting?
It may be a problem with the damper panels that are situated between the freezer and the refrigerator. Most people note a problem when the damper doors stop opening and food becomes warm. In your case the doors may be not closing properly.
This may be mechanical, the damper louvers assembly is broken, or it may be electrical, the relay switch and motor assembly that operates the damper is not operating properly.
In side by sides the damper is usually in the upper side rear of the refigerator. If you can peer into it, you may be able to see light from the freezer (freezer door open) which would confirm the louvers are open.
Quick fix? duct tape a portion of the opening. It will restrict cold air flow. Costs little, and if you are not particular will work. Other fix. Call a repair man and be prepared to pay about 200 for the parts and labor.
Aloha
Posted on Sep 18, 2009
woodchuck789
  • 4066 Answers
SOURCE: Refrigerator temperature running too high
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Oct 03, 2009
  • 35 Answers
SOURCE: My refrigerator was not cooling
the defrost thermostat may be bad
Posted on Feb 28, 2011
reyjoshua07
  • 1157 Answers
SOURCE: My refrigerator is still working
Hi erin_mcnally,
This complaint is usually the result of a defrost problem. The first thing to check in this case is the freezer area. Look at the back panel inside the freezer. If you notice frost covering the back panel, you have defrost problem.
Reminder: Unplug your appliance or disconnect power to your unit before you begin any repairs
If the problem is not a defrost issue you may have a problem with the damper that goes between the freezer and fridge compartments. This is usually an adjustable "flap" that opens to allow cold air from the freezer to enter the fresh food side. Most top freezer and certain side x side refrigerators have an adjustable flap. That means its set open at a certain point and doesn't open and close when the machine runs.
Most newer side by sides and bottom freezer refrigerators have an electric damper that opens and closes as the machine runs. These are machines that have separate thermostats for the freezer. The machine can call for cold inside the freezer without affecting the fridge side temp by keeping the damper closed.
To test this will require you to locate the damper assembly. Once you find the damper on your machine, make sure the thermostat is on and you hear the freezer fan running. Normally at this point you can feel the air coming through the vents on the damper. Certain models will close the damper when the fridge door is open. So you will have to hold in the light switch or tape it so the machine thinks the door is closed. After you do that and you still don't feel air, remove the damper cover. Check to see if the damper door is closed. If the door is closed, make sure it isn't froze shut. Manually open the door with your fingers to make sure it can move freely. If it can move freely then replace the damper. Sometimes some insulation or foam can fall into the path of the damper and cause it to jam. If you look inside the damper and it's open but you don't feel air, check your evaporator freezer fan.
The Freezer Fan should be running if the machine is not in defrost mode. If the refrigerator is warm and the compressor is running, the freezer fan should be running also. If not you are going to have to gain access to the freezer fan and check to see if it has 120 volts. If the fan is getting the proper voltage and is not running, replace the fan. If the fan is not getting voltage and the compressor is running, you more than likely have a problem with the defrost timer. Try turning the blade on the fan to see if they move freely. I have seen where a fan has developed rust and that prevented the motor from turning. It may start up if your get it a turn so watch your fingers. If it has rust and that's why it stopped, you should replace it anyway. It will just happen again. But at least your machine will work for the time being.
Hope it helps.
Thank you for using FixYa.
Posted on Jul 05, 2011
TAYLOR 702 ICE CREAM COMPRESSOR SHORT CYCLES AND PRODUCT NOT FROZEN
call in the technician as it may be low on refrigerant gas from a leak
Mar 25, 2016 | Ice Cream Makers
Frozen filter
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not opperating properly.
Feb 17, 2014 | Amcor Dehumidifiers
Filter frozen
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not operating properly.
The refrigerator on our Roper side by side refrigerator/freezer has frozen everything from veggies to milk. Any clue as to what the problem might be? Greg Russell
Your thermostat has probably got its contacts withing fried together and it is not shutting down.
Obviously the compressor and fans are working fine. It has to be in your control. Your ice box has a mercury based control. The temp is controled by it and nothing else. It can fail by burnt out contact. (open) OR Fried together contacts (stuck together won't shut down). OR Loss of mercury in the probe.OR kinked probe.
Aug 14, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
It keeps running and doesn't shut down. Freezer
Check condensor for clogged coils and make sure the back is on it. (The pasteboard covering over the Service Opening on Bottom Rear)
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 17, 2011 | Whirlpool Refrigerators
Ice Cream and frozen waffles won't freeze.
LOL ! SO in other words in plain english your repair man told you needed a brand new refrigerator - Ok from your description here we can rule out low refrigerant or compressor problems, defrost timer and controlboard issues. I too have waffles and they DO get frozen although not as hard as ice - the less water molecules they have the less they are frozen hard. but nonetheless, my waffles are NOT soft, neither is ice cream
What I would ike you to do is put one of those refrigerator/freezer type thermostats, you can get those round ones, place it in your freezer leave it there 24 hours and look again - Optimal freezer temps is 0F once compression cycles off - if you areusing the extra cold setting, -10F - For refrigerator don't go over 40F - optimal temp of 36-38F.
Another method you can place a bowl of water and use one of those probes and measure the temp of the water in your fridge. If your temps are within safety levels do not worry - your ice is frozen and your frozen food is frozen - Some ice cream tend to be softer, especially the extra creamy type. If your refrigerator has a dial to adjust temps, raise it slightly and wait 24 hours and check your temps again you might need to bump down the temps a bit - if you have a control panel and 2 settings they are usually COLD or COLDER, set it to COLDER and check again - in the COLDER setting your compressor will shut down once your freezer hits -10F that should be quite enough to have even your waffles and extra creamy icecream frozen - if some of the liquids in your refrigerator is too cold or freezes, set it back to COLD or re-adjust the dial. Once you determined that your freezer AND refrigerator are within SAFETY levels as per the food safety guidelines and using the proper methods of testing, then you have nothing to worry about. Make sure your fridge and freezer are not leaking cold air by checking your door gaskets using the famous dollar bill technique by closing the door on the dollar bill and trying to pull it out - if there is no resistence and can easily come out, you have a gasket leak - check in different places on the gasket. As long as you can determine that your freezer and fridge temps are SAFE don't spend a dime ! If your temps are NOT in the safe range you probably have leaky gaskets - if the compressor seems to run all the time, you probably have dirty condenser coils that need to be vacuumed cleaned or dusted off using a condenser brush.
Aug 17, 2009 | Amana Refrigerators
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Open Questions:
GE GSS22SGM Side by Side Refrigerator Logo
32 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
