Question about Diamondback Session BMX Bike (20Inch Wheels)
Why does my back wheel keep making a knocking when i ride it on my diamondback session?
  • 30 Answers
Check your sprocket and hub.
Posted on Apr 11, 2011
Knocking noise
check the sprocket sometimes they are put together with screws and it might be extruding out and rubbing.
Mar 04, 2014 | Yowza Fitness CAPTIVA - Worlds 1st...
Knocking sound at steering wheel during turning of mistubishi adventure
It sounds like a ball joint is worn, possibly the rack end ball joint or tie rod end.
With the bumpy ride it could also be that the front shock absorber has failed.
Jack the front wheel up on each side in turn, grab the wheel at each side and shake it back and forth as hard as you can. If you hear or feel looseness, the problem is in the steering, as above.
Then shake the wheel while holding it at top and bottom. If you feel looseness then, the problem is in the front suspension wishbones.
Repeat this on the other front wheel. Let it down on the ground, then bounce each front corner up and down as hard as you can (you might have to have a second person with you doing this). If you hear a clunk or feel excessive bounciness, it is the shock absorber. When bouncing like this, the car should resist, and not keep bouncing when you let go.
Apr 11, 2012 | Cars & Trucks
I was riding my diamondback viper and i put on the brakes, and when i let go they were still touching the rim. They seem to be jammed in place.
Internal brake cable friction or gross maladjustment is at play here. The brakes must spring back under their own spring tension or they will stay engaged.
http://www.parktool.com/blog/repair-help/categories/brake-service-and-repair
Simple search engine querieswill find answers to well0-crafted questions like "how to adjust...."
Aug 06, 2011 | Diamondback Viper X BMX Bike (20Inch...
Seat keeps coming down
http://www.diamondback.com/downloads/owners-manuals/
See page 22...
http://www.diamondback.com/wp-content/uploads/2008/03/2012_OM_DIAMONDBACK.pdf
While you're at it, get a handle on how quick releases for the wheels work or more than your seat will be going down when you ride.
Jul 08, 2011 | Diamondback Sorrento 26" Mountain Bike
Just bought a Diamondback Viper 20". Have always had Diamondback BMX bikes (Grind and Joker), and this is the first one that has had a handlebar issue. They move forward and back, just while riding....
Do you mean the stem is allowing them to twist? THAT is a dangerous situation and you should get a real competent Bike Shop, not just a dealer, to look it over. If the tighening bolts are bottomed out it won't hold tight. Or if one side is bottoemd and the other gap is wide.
Using this picture as a general guide since it might not match your stem...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280652429524&clk_rvr_id=242489366593&item=280652429524&lgeo=1&vectorid=229508
The gaps should exist and be even. Not metal to metal. Handlebars and stems come in different diameters. Perhaps yours are incompatible.
Jun 21, 2011 | Diamondback Viper Bmx Bike (20inch Wheels)...
Looking for fenders for a Diamondback Serene Citi Classic, 17" frame and 26"wheels.
Order at your local bike shop, fenders are usually universal, not brand specific just need the right size, and they can install them too for a nominal fee. They usually are in stock.
Sep 28, 2010 | Diamondback Serene Citi Classic Women's...
Fort Adjustment
Check the top of one of the forks, there may be a knob type dial that you can turn clock-wise or anti-clock-wise, turning it one way will give you a stiffer ride, turning it the other will give you a softer ride. Some forks don't have this pre-load adjustment however.
Cheers.
Jul 09, 2010 | Diamondback Response 26 Men's Front...
Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Aug 17, 2009 | Cycling
Diamondback Session BMX Bike (20Inch Wheels) Logo
91 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
