Question about Sewing Machines
I'm trying to do shirring?
I'm using elastic thread in the bobbin and I've tried loosely and tightly winding the bobbin, but nothing seems to be working. When I put the bobbin thread in the case, it's too tight tension wise so I tried not putting it through the tension in the bobbin case. When I start doing a straight stitch the needle thread keeps getting caught around the bobbin/bobbin case? Help! Nearly the same problem. Do you think loosening the screws on the side of the bobbin case will do the trick? Mine will go through, but stretches the elastic before it gets sewed, causing the elastic to be too tense when it's in the fabric. I'm using a Pfaff Select 1548.
I had a problem with my Pfaff 7570. First, I loosened the bobbin tension quite a lot. Second, I lengthened the stitch to 4.5. Lastly, as I was sewing. I gently helped pull the fabric as the machine sewed.
Posted on May 09, 2009
  • 876 Answers
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Posted on Aug 07, 2008
My sewing machine don't want to work the elastic tread that you use for smocking. I put it on the bobbin. Also, were can I download a free service/ repair manual?
To seek a manual, search the internet for:
Manufacturer + Model + the word "Manual"
Be sure you hand-wind the bobbin with the elastic thread. You may also need to loosen the bobbin tension a bit if the elastic thread is stretching too much while stitching.
Shirring with Elastic Thread
Pretty Ditty Shirring tutorial
How to use elastic thread How to sew with Elastic thread
Tutorial shirring with elastic thread Made By Rae
Dec 02, 2015 | Sewing Machines
Elastic thread pulled too tight in Janome Sewist 525S
I would say your tension spring is shot on your tension assembly. replace it.
Mar 27, 2017 | Janome Sewist 525S Mechanical Sewing...
Any advice on shirring with an old elna lotus sp. Brought out of retirement as my Brother refuses to shirr! bobbin threading etc can't find the manuals.
Suggest you watch in utube 'sewing with shirring elastic' not necessary be your model as the basic application is similar in other models.
Nov 11, 2013 | White Sewing 1521
How to use elastic thread in a Bernette 66
Did you change the needle to one designed for elastic thread?
Aug 21, 2012 | Bernina Sewing Machines
I am trying to shir using elastic thread in my bobbin but my fabric will not shir & my elastic there jams causing me to start all over. I have studied many tutorials. It seems I need to tighten the...
Have you wound the bobbin with the shiring under tension? you need the shirring elastic to be stretched somewhat as it goes onto the bobbin so that when stitched out, it relaxes and pulls the fabric up.
And yes, usually you need to tighten up the bobbin tension also to stretch the elastic some more.
The Ellure has a horizonal drop in bobbin so you will need to access this to adjust the tension. This may require unscrewing the two screws holding down the needle plate (metal flat plate you sew over). Take this off and now you'll see the bobbin holder area clearly. Look where the tension spring is, the little groove you pull the thread into when threading up. Is there a small dial just near this, about 7mm across? it will have a groove in the top and hopefully a + and - marking.
IMPORTANT: carefully make a note of where it is set now. Take a picture or write a little diagram down so you can get it back to normal setting. Use your little accessory screwdriver and carefully turn it one click to +, then test sew. YOu may need to turn it up 3 clicks to get the elastic stretched enough. Just make sure you know where to set the dial back to when you are done.
Also, remember you won't be able to shir heavy fabric, just light weight cottons work best.
I find that stitching lots of straight lines of shirring like you see tube bodice sundresses made in ready to wear is very hard, factories will have a machine that sews 20 rows at once. And getting enough gathers is trial and error with a domestic sewing machine.
Here's how I do it. Turn down top selvage edge of the fabric width you want to gather, turn down about 10mm and straight stitch around. Now on the wrong side with a sewing marker pen rule lines down from here across the fabric width spaced 1 cm apart. Now lie shirring elastic on these lines and stitch over it with a narrow zig zag stitch making sure not to catch the elastic with the needle. Start each sitching seam one cm from the raw edge of the fabric and finish the seam the same way.
Now I pull the elastic up from each side pulling all of them evenly until I"ve got it gathered enough. Now place right sides together and stitch the fabric into a tube catching the elastic ends in and securing them.
I hope this helps you out.
Jul 19, 2011 | Baby Lock Ellure
I am trying to do shirring with elastic thread on 100% cotton fabric, but it is not working. The result is very poor. I hand wound the bobbin with elastic thread but unfortunatly is doesn't stretch out...
I hand wind the bobbin but use regular thread for my top thread and set my machine with the longest stitch length. I put my tension on 3, my friend uses 4 but I guess it depends on your machine.
Jan 28, 2011 | Singer Sewing Machines
I have a Brother 70 stitch computerised sewing machine. I have managed to fill a plastic bobbin with shirring elastic by not using the little tension knob, only the hook section of it on top of the...
You should not have both, bobbin and top thread filled with elastic, it may screw up your timing. And you are talking major expense to fix. Use regular thread in your bobbin.
Jan 02, 2011 | Brother Sewing Machines
My machine is not shirring. I hand wind the elastic on the bobbin properly(in fact 4 different ways from no tension to medium tension on the elastic). I have it on a straight stitch and selected 4 as the...
you are doing it wrong, thread the machine top and bottom as normal, shirring elastic on your lap, select a small zig zag or pattern, sew and as you sew pull the shirring elastic taught, mif you wind the shirring elastic on the bobbin you will mess the tensions up.
Apr 22, 2010 | Brother CS-100-T Computerized Sewing...
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Sewing Machines Logo
655 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
