Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
SOURCE: programming my toshiba universal remote
http://www.tacp.toshiba.com/tacpassets-images/models/27AF45/docs/27AF45_om_E.pdf
Scroll down to the remote section page 12 -13 its in there... I have this same remote and just programmed it.. Good Luck to you!
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
SOURCE: Can't program my Toshiba CT-90302 remote to my DirecTV reciever?
step 1, select the funtion you wish to program on left side.
step 2 hold down the recall button while entering the 3 digit code for the device you wish to program
step 3 have a beer, you are done
Here is the link for the owner's manual that also has the codes
http://remotes.com/remotes/documents/Toshiba/CT-90157.pdf
