Question about D-Link Dns 323 2-Bay Network Storage Enclosure - Nas Server (S6070845)
I have 2 D-Link DNS323s. Both have been working for about a year as media servers. Recently one of them disappeared from the network. No changes were made to the netowkr or computers on it. Both NASs have fixed IP addresses. D-Link's Easy Search only sees one of them. Direct entry of the down-NAS's IP address yields nothing. No response to Ping. How do I get into this thing to see what the problem is? Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
Try to replace network card
Posted on Jul 17, 2017
  • 59 Answers
SOURCE: Problem Accessing Shared Folders in Network Stoarage Device
vista is only going to complicat things, try re mapping the drive, delete the shortcut and use my network places to find the drive then make a new shortcut to it if you can access it from there, i've had windows 2000 do the same thing especially with my laptop that I take to school, it a lot of times its due to changing ip's but occasionally windows just seems to forget where stuff is on the network and needs to be reminded. shortcuts can be made by draggin the folder to the desktop or desired location or right click the share you want mapped and select map network drive.
Posted on Apr 21, 2007
viaujoc
  • 60 Answers
SOURCE: Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
Posted on May 11, 2008
Fjandr
  • 22 Answers
SOURCE: Setting up IP address on server
Download and install <a href="http://www.wireshark.org/download.html">Wireshark</a>.
After installing, click the first button on the toolbar to list available capture devices. Select the interface you use to connect to your network (wired or wireless card) by clicking the "Start" button next to it.
Power off and back on the print server. Watch the log on Wireshark, and look for the D-Link identifier under the "Source" tab. In the same row, it will tell you the IP address the print server has assigned to it. You can then change your computer's IP to be in the same subnet (match the xxx's in the address xxx.xxx.xxx.yyy), allowing you to connect to it.
Posted on Feb 08, 2009
gripfitter
  • 557 Answers
SOURCE: I have installed the DP-301U print server on my
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Posted on Oct 21, 2009
  • 742 Answers
SOURCE: How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Posted on Oct 22, 2009
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
Anyone recommend a Media streamer that works with MCA?
I'm using a Seagate Home Theater Plus with my MCA. I can hit it both as a media server or as a network drive. I have found that if I hit the MCA as a media server, I do not see my video files that have a .ISO file extension. Plus when accessing the music jukebox from the MCA media server the displayed song title is not always the song that is playing. The easy work around for both is to just hit the MCA as a NAS vice media server. Other than that it works just fine.
Aug 12, 2010 | D-Link Televison & Video
USB printer HP 1020 Plus in DP-301U
Did you try using LPR mode instead? I find it works more relyable with any print server. SMB (windows network mode) is ****. I have had simalar problems with another printserver.
Apr 17, 2009 | D-Link DP-301U (790069251979) Print Server
Lg me770 shine. how do i set up to have mms
i used this for mine. it works alright for recieving and sending. but im still having trouble recieving from black berries.
go to menu
settings
connectivity
network
network profile
bearer: GPRS
APN: wap.cingular
user ID: blank
password: blank
primary server: 0. 0. 0. 0
secondary server: 0. 0. 0. 0
then press ok.
now go to menu
messaging.
message settings
multimedia message
network profile
profile name: Cingular MMS
MMSC: http://mmsc.cingular.com
internet mode: http
proxy ip: 066.209.011.032
proxy port: 80
connection: media net
hopefully this works for you guys.
Dec 11, 2008 | LG Shine KE970 Cellular Phone
Can't connect to default network.
Try to power cycle your router. Unplug the power for 30 seconds then plug it back in. If that doesn't work, try to change the channel of the router. That should do it. If it still not working, there's a problem with wireless adapter's driver. You need to use update one.
Nov 02, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Ps3 error 80710723
This same problem happened to me awhile ago. The way I fixed it was I went under settings to network settings. Then went down to media server connection and disabled that. Once I did that I had no trouble at all updating games. Hope this helped :)
Oct 18, 2008 | Sony Playstation 3 (PS3) Console
Having to reset (unplug) daily
Check the Printer spool service. If documents are getting increase in que, restart the Printer spool services. It will definatly solve your problem.
Oct 03, 2008 | D-Link DP 300U (DP-300U) Print Server
Home networking
Do you get link lights on the switches, they may need to be in an uplink port.
Aug 05, 2008 | NetGear FS608 Networking Switch
Network & Speed Problem
I suspect that the network interface card failed, & that's why you get the error message. Try disabling it from the BIOS & see if the error message disappears. If it did, then you have a failing network interface card & need to install anew one.
Jul 22, 2008 | IBM Netfinity 3500 M20 8657 Server
D-Link Dns 323 2-Bay Network Storage Enclosure - Nas Server (S6070845) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
