MGA/Mitsubishi TV Model CK2582, hooked up cable, tv will not go past channel 36, how do you auto-program tv?
SOURCE: Cant access "Antenna" in tv menu to change to cable
It sounds like you haven't selected cable in the "pull-down" menu. You see, you physically have to tell your tv if you're selecting "over-the-air" programs(free), or cable. Select the cable option &
then run "auto-select". Your tv will go through it's steps & find your cable stations. I hope this helps.
Posted on Oct 23, 2007
  • 1153 Answers
SOURCE: Mitsubishi VS-5051
It is called Text in your Close Caption. Turn off
Posted on Nov 26, 2007
  • 112 Answers
SOURCE: programming digital channels
The problem is not with your TV. You need a digital box to unscramble the channels.
Posted on Dec 20, 2007
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Posted on Jan 15, 2008
  • 2920 Answers
SOURCE: TV WONT GO PAST CHANNEL 13
you have to set the tv to cable and then let it do a channel search to find all the channels. sounds like right now its on air and not cable
Posted on Dec 06, 2008
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
I have a mga tv 1988' model cs1946R. I only get 11 channels from comcast my cable provider, my other tv (newer) get all channels. How do I programe my old mga to get more channels( I know i won't get as...
Your old tv does not have more than 11 slots to store channel .
Thats why you are not able to get more than 11 channels .
But let me confirm it .
SAM ANDERSON
Sep 18, 2008 | Televison & Video
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Can't get it to go above channel 23... (nothing wrong with cable hook up)
all done so far looks good. But the part where you went into the menu is about i'd like to talk:
before you send to auto-program feature. try to find changing the band where the tv is working now.
Let me explain.
The tv is looking channels in the antenna or air band. Make sure you change the selector to CABLE.
this selection usually it is previous to send to auto-program.
if all this was done and nothing change, we need to send the tv into the workshop to check the tuner and voltages related to it.
Apr 14, 2009 | Televison & Video
36 inch toshiba Tube tv manifactured in 1997
Program TV =
1) set-up.....Select CATV also called STD Cable
2) Auto-program channels.........
.......Owners manual ? Let me know.................T.
Dec 11, 2007 | Toshiba 32AF43 32" TV
MGA 1989 19inch standard tv. - model #CS-1946R
Try this. I the control box under screen (with a door) is a botton TV/CABLE.HCR. Try pressing this button to get more channels. Mine was on TV, but needed CABLE. Best wishes.
Dec 06, 2007 | Televison & Video
T.v wont go past channel 36
I have not worked on this particular model of Sony. What I will say is for the ones that I have worked on.
If you are on cable, the set should be in the CATV or cable mode.
Go in to the user menu and look for section of the menu for the channel setup. There should be a prompt for auto program.
In almost all of the TV models the original factory remote is required to make any set-up changes in the TV set. What I explained is for TV sets that allow changes to be made from the front panel button controls.
Jerry G.
Nov 23, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Feb 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
