Question about Car Audio & Video
How can i change the display color on sony car audio cdx l410 from orange to green?
SOURCE: Changing faceplate colors.
only the display changes colors.... your deck is doing what it was designed to do!
Posted on Apr 03, 2008
  • 5 Answers
SOURCE: sony cdx mp40 bus audio in
ok dont know if you will check up on this but fm transmitters are all garbage. for true undistorted sound go to an electronics store and ask for a rca to headphone cable. then just hook it up to the rca input and run the cable out of either the unit or somewhere on the dash. this will alow for a true connection and if you buy a brand name cable i.e. monster, radioshack, sony etc. should sound amazing. always happy to help.
big c
Posted on May 23, 2008
perryhawk
  • 13 Answers
SOURCE: I need the fitting instructions
Try the Sony website.
Good luck
Posted on Aug 05, 2008
experttv
  • 203 Answers
SOURCE: Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Posted on Sep 14, 2008
  • 68 Answers
SOURCE: how to set time on
hold the source button for like 10 seconds and go over on the arrows and then find the time clock and set the time,.that should work i hope it works
Posted on Nov 20, 2008
What is the wiring color code for a sony cdx-sw200
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope that is what you were asking for.
Nov 08, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
May 07, 2010 | Sony CDX-RA700 CD Player
How do i change the color from red to green?
This is a link to Sony for your CDXGT510 Owners Manual. Reference page 10 for changing the display illumination color.
http://www.docs.sony.com/release/CDXGT510.pdf
Mar 10, 2010 | Sony CDX-GT510 CD Player
Wiring diagram, sony cdx 3100 car cd player
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
Feb 24, 2010 | Car Audio & Video
Have a sony cdxm610 faceplate won't close and has no power.
WHITE AND ORANGE WIRE IS FOR ILLUMINATION WHICH IS NOT NEEDED IN INSTALL. LIGHT BLUE IS FOR POWER ANTENNA AND THE LIME GREEN SHOULD BE FOR LEFT REAR SPEAKER( SOLID GREEN IS POSITIVE AND GREEN WITH BLACK STRIP IS NEGATIVE)
Aug 08, 2009 | Sony CDX-M610 CD Player
I need to hook up cd player
something i found today on google. hope it helps.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony CDX-CA400 CD Player
Wiring diagram
First, you can buy a harness for whatever vehicle you're putting it into and the colors on THAT harness will match the harness on the radio.. With that said:
black---------ground
red------------12V Switched (ignition)
Yellow-------12V (constant)
blue-----------power antenna
blue/white--Amp turn on
orange-------dimmer
white--------Left front+
white/blk---Left Front -
Gray---------Rt Front+
Gray/blk----Rt front-
green--------left rear+
green/blk---left rear-
purple--------rt rear+
purple/blk---rt rear -
Aug 04, 2008 | Sony CDX-M610 CD Player
SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
Mar 18, 2008 | Sony XPlod CD Player w/MP3 Playback...
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
