Question about Sony HDR-FX1000 Mini DV Camcorder
Mecanisim not loading the tape - Sony HDR-FX1000 Mini DV Camcorder
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • Sony Expert
  • 65 Answers
Posted on Aug 30, 2015
CDA wc370 dishwasher wont start,
Clean latch mecanisim ,,,,Close door fully , with a bang ,,
May 14, 2012 | CDA Dishwashers
Where to locate switch off mecanisim from rental company
you have come to the wrong place for an answer to this question=answer would be to pay your bill and have them turn service back on.
Apr 10, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Model # 44722 Portable Washer Are you suppose to open washer to balance load while washer is in spin? I did and the tub stopped abrutly moveing the machine about 1 foot across the floor.
a safety mecanisim built into washers is the top lid switch it detects when the lid has been opened if you do this whilst its spinning it will engage a powerful brake as you saw to stop the barrel so you dont reach in and loose an arm its perfectly normal. if the washer goes unbalanced wait turn the power off at the wall wait till it stops spinning then re arrange the cloths
best of luck
please take the time to rank this advice
merry christmas
Dec 07, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Tape not loading
Drop it on a carpeted floor from half a metre
I got the solution fromFixYa on 3rd Feb 09 it worked for me
Dec 16, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
Windows wont go up and down
Hi
I had the same problem with my 2001 LeSabre rear window. Use a small paint scraper to gently pry the door panel in the area of the plastic buttons. Remove the plastic cover surrounding the door handle and there will be a screw to remove. The door panel should now be able to lift up at the window ledge and then you can remove the wiring harnesses from the panel to get it out of the way.
With the window jammed (with a wooden wedge) in the up position, you will see a hex head screw holding the window mechanism to the glass at each end of the glass. Just loosen these two screws about one and half turns. Look at the motor bracket and you should see approx. 3 or 4 hex head screws holding the motor to the metal door panel. Remove those screws and you should be able now to wiggle the window motor and mechanism out of the door panel. You will probably find that the braided cable connecting the motor pulley to the window arms has broken or is jammed inside the motor. I have taken this apart, reset the cable but it only worked once again before it jammed up again inside the motor. Go to your local Auto Wreckers and order a replacement motor and mechanism complete assembly for about $150. GM wants double that price! Good luck!
Mekanic
Aug 06, 2008 | 2001 Buick LeSabre
Not accepting tapes
Your average vcr load motor runs a 6 to 12 v dc and the load carriage will generally have tight spots as it loads.
what you will most likely need to do is realign the load mecanisim and check the mode switch first.
depending on the wear of the unit the load switch may need to be replaced.
Some vcr's also have a habit of jumping a tooth on a cog so it would be a good idea to check and see if this has happened.
Feb 26, 2008 | Televison & Video
Sony HDR-FX1000 Mini DV Camcorder Logo
89 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
