Question about Altec Lansing ADA 215 Computer Speakers
Hello I have a set of Altec Lansing ADA215 speakers, and one of my speaker has very low sound level. This was not before I dont now what happend I hope you guys have an idea. Thanks B.Versloot
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Apr 10, 2011
Were in providence can i find a cord to my altec lansing model:ADA215 speakers
https://www.google.com/search?q=altec+lansing+model%3AADA215+speaker+cables+&ie=utf-8&oe=utf-8&aq=t&rls=com.yahoo:en-US:official&client=firefox&channel=sb
Oct 02, 2014 | Audio Players & Recorders
Makes a loud noise when i turn on and no sound plays. I don't think i need drivers but either way they're impossible to find. I have Altec Lansing ADA215 Computer Speakers.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 31, 2010 | Altec Lansing ADA 215 Computer Speakers
Altec lansing acs45.1 cannot increase volume level by using arrow buttoms on top of cube speaker...sound does come out but a very low levels......have pret
This is a loose connection between PC and the Sub-woofer. The cables may damaged or it may be a hard ware problem.
Think this is helpful !
Aug 11, 2010 | Altec Lansing ACS 45.1 Computer Speakers
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Jun 24, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec lansing ada 745
need to check your control center,then if thats not the one"it should be set @ 3/4 volume....
if no diff,,,,,then you need to go over checking every program that shares it,,,has their own volume control,,,somewhere there is the problem,,,maybe real player,,,media player,,,flash player etc...
thnks ttyl
Polywoggy1@hotmail.com..
Mar 10, 2008 | Altec Lansing Multimedia Computer Speakers
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
One drive for Altec Lansing Technologies Inc. 'ACS-295' dell
Hello there
What kind of help on specific device from altec you need?
be more specific
Nov 28, 2007 | Altec Lansing ACS 295 Computer Speakers
Altec Lansing ADA 215 Computer Speakers Logo
85 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
