Question about Sharp (AR-NB2N) (ARNB2N) Print Server
How do you install an AR-NB2N on a Sharp AR_168D
007tech
  • 95 Answers
SOURCE: I have an error code of L3-00 on my Sharp AR 168D.
L3-00 indicates scan carriage motor trouble. The carriage with all the mirors on it is not moving at all (scanning) or is not moving at the required speed so it does not reach its "home" position. If restarting the copier does resolve the issue....
A few things to check... When you turn copier on does carriage move at all? if not then the motor could be bound up (not turning) - also make sure the cables pulling the carriage are properly wound. remove the main glass and make sure there are no obstructions in the way of the carriage (a loose cable maybe or dirt) can you move the cable by hand freely? if the motor locks up it could be really hard to move the carriage.
The carriage seems to be moving freely (by hand and when you turn the copier on) it could possibly be the "home position" sensor that is faulty and not reading the correct position of the carriage.
You can the copier in test mode to check either the motor or sensor. press the following keys one after the other # * C * then press start/enter , press 1 and start/enter again, sub code 1 will test the motor and sub code 2 will test the sensor.
So it could be a bad motor or sensor or the MCU board that drives the motor (or may just need a good cleaning).
Good Luck.
Posted on Mar 26, 2009
  • 67 Answers
SOURCE: H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Posted on Apr 09, 2009
taran_2005
  • 10515 Answers
SOURCE: Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Posted on Jun 11, 2009
  • 990 Answers
SOURCE: Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Posted on Aug 26, 2009
SOURCE: Error on Sharp AR-168D Copier
The manual says to turn off and unplug the machine and wait for 10 seconds. Then plug it back in and turn it on. If this doesn't get rid of the problem contact your sharp dealer/service man.
Posted on Feb 11, 2010
HAVING TROUBLE INSTALLING A NEW TONER CARTRIDGE IN SHARP ARM 257. COPIER IS NOT RECOGNIZING IT...F2 04
AR-270NT is no longer accepted by that copier. You must use AR-310NT. Or, you have a bad chip on the back of your cartridge.
May 27, 2014 | Sharp AR-168D Black and White Copier
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
Error H3-00
Aug 26, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D will not print
you should change your printer data cable or fix correctly with printer port.
Jul 30, 2009 | Sharp AR-168D Copier
Check
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Button manager on Sharp 168D won't install. So I can't scan
Uninstall Button manager, if you get a message telling you that it is in use, go to task manager, processes tab, click on btnman.exe then end task.
Re-install the application.
Mar 27, 2009 | Sharp AR-168D Copier
Drum replacement
open the right side door.open the front door.unscrew the devoloping unit lock screw. pull the unit out. pull drum unit out fromthe copier.
Feb 16, 2009 | Sharp AR-168D Copier
SHARP 168D - Won't print from RDP session
Does the printer print directly without an RDP session?
Jun 25, 2008 | Sharp AR-168D Copier
Computers & Internet Logo
71 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
