Question about Jacuzzi Pool & Spa
My Essence Echo Spa jacuzzi is giving us an error "FL". Can you tell us why it is saying this and how we can fix it? Thanks!
  • 310 Answers
FL stands for Flow. It is a diagnostic code that is indicating that either the the flow/pressure switch has failed, or the pump is not pumping enough water to operate the spa safely.
If it is the pump, you might try to lean out the impeller housing as its common to see a pine needle or other such blockage affecting the pump.
If its the switch, just buy another generic switch and swap it out. It would only take a few minutes.
Posted on Apr 11, 2011
Need to find local repair shop for my pool pump...not sure why wo't work
do a local google search online for a motor shop in your area.
sounds like the jacuzzi pump is bad. maybe a bad winding or bad bearing.
Rod
US Parts Center
Jul 19, 2012 | Jacuzzi Pool & Spa
How can I unscrew the lid of the Maghum Jacuzzi pump... it is too large for a wrench...
2X2 AND A HAMMER, THE RIBS GIVE YOU JUST ENOUGH SPACE TO TAKE THE WOOD EDGE AND SMACK IT, GO FROM ONE SIDE TO THE OTHER, ONE OR TWO HITS EACH TIME.
IT WILL GIVE IN AND LOOSEN .. USE MAGIK LUBE NEXT TIME ON THE THREADS AND O-RING AND YOU WILL NOT HAVE THIS ISSUE AGAIN..
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL 32750
I HAVE SOME PARTS FOR THESE PUMPS LISTED ON EBAY.
PLESE VOTE YES OR NO IF I WAS OF HELP
May 19, 2012 | Jacuzzi Pool & Spa
What does the "FL" code
Fl stands for FLOW error code. This means that either the pump is not pushing enough water, or the pressure switch that senses water flow through the heater is not functioning. This are inexpensive and easy to fix yourself if it is just the pressure switch. Look on or near your heating element for a small disk switch with two wires coming out of it. Remove and replace this part.
Feb 15, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
I have a Jacuzzi Z 145 spa. I was constantly getting an FL error. Purchased a new switch, put it on and when I turn the spa on I immediately get a circuit blow. What could be causing this problem?
Its possible your heater has a ground fault. If the old pressure sw was giving the FL code the system would not send power to the heater. Now with the new sw working power is being sent to the heater.
Oct 23, 2010 | Jacuzzi Pool & Spa
My jacuzzie starts and stops wen it is runing i have a fl code
FL is a flow error, you may not have enough water going over filter housing. Jets are they open?
is your heater fitted with a pressure switch? when on FL locate pressure switch wheel and turn all the way anti clockwise until it stops then slowly wind back until you hear a click reset in control box - you have reset pressure switch.
If you have done this and still show FL or heater is not fitted with pressure switch then your LOW speed on pump maybe faulty (new pump) or heater maybe scaled up with lime scale and reducing water flow through heater - remove scale from heater, flush through and increase ANTI-SCALE
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 07, 2010 | Jacuzzi Pool & Spa
I have a Jacuzzi spa that has a FL on the read out.
the FL code is usually an insufficient flow fault. you may have a dirty filter or a faulty flow switch/sensor.
Dec 27, 2009 | Pool & Spa
Pool & Spa Logo
291 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
