Hot water comes on but then runs cold after a minuate then goes hot again. The water appears to be hotter downstairs
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
If you have lukewarm water.. and at times it's hot.. then warm. or after running hot for a while and it cools.. chances are you have a cracked or failing dip tube.
The dip tube is just what it sounds like. a tube that delivers cold water to the bottom of the tank.. to mix with the hot water.. this keeps the hottest water at the top for faster delivery.
If this tube is cracked near the top.. or along it's length.. you may get some hot water.. then cold.. then warm..etc etc.
They are inexpensive to replace.. but as always exercise caution and follow proper procedure to relieve pressure, water supply and power/fuel before attempting a repair.
Generally this tube is inserted right where the cold water inlet pipe is on the heater.
A good plumber or water heater replacement or repair company could inspect fix and replace for a lot less than a new water heater.
Best of luck
Posted on Apr 10, 2011
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
Sep 23, 2014 | Water Heaters
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Only hot water makes it to the tub. I can hear cold water running. I can feel it traveling through the hose, but it does not get into the tub. Why (and where is the cold water going)?
hmm...so you're certain that the cold water is actually going in someplace huh? ok, try this...run it like you have it now...put your hand in the water flow and feel how hot or warm it is...now turn off the cold water and see if the hot water gets hotter...if it does,then try the opposite, turn off the hot water and see if there is still water coming into the tub...let me know what happens
Jun 10, 2012 | Maytag PAV2300 Top Load Washer
Weak air conditioner air flow and very hot upstairs.
Check the fans are all working ok and make sure there isn't a louvre closed in the duct
May 04, 2012 | Heating & Cooling
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
No water coming from my hot water taps, upstairs or downstair.
Is there any water at all coming out? If not turn the cold water tap on the hot water tank on.
Nov 11, 2009 | Emerson Water Heaters
Dishwasher has no hot water running into it only cold
Have you checked your hot water heater downstairs in the basement? Are you getting hot water elsewhere in the house?
May 24, 2009 | Dishwashers
Electric shower
water pressure not sufficient
Mar 21, 2008 | Heating & Cooling
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
