Question about Mabis NebXP Portable Handheld Compressor
Few bubbles and no mist - Mabis NebXP Portable Handheld Compressor
This is for the John Bunn Compact Ultrasonic Model JB0112-066. I found that the liquid inside the nebulizer ultrasonic chamber had dried up or leaked out and that was the cause of improper mist flow. You can tell if it's low on fluid by tipping the unit on its side and looking through the transparent membrane. If it's only 3/4 full or less it need fluid. If you're handy you can open up the unit by removing two screws located deep in the two holes on the bottom of the unit. Carefully pull the top off and lift out the guts. You'll see a metal plate with several little screws - undo them and lift out the rubber gasket, carefully pry out the round disc with the two wires and the rubber gasket under it. You can then use a syringe to refill the chamber with distilled water until you can see the water level about 1/4 " from the top (actually the bottom). Close everything up and test it. Hint: when putting the guts back be sure the circuit board is seated below the blue on/off button and that the two posts are coming through the circuit board. If you have any resistance when putting the top on it means the circuit board is not seated deep enough. Good luck! This will save you $75 or more for a new unit and you get lots of kudos from your spouse for being so smart !!
Posted on Jan 24, 2013
  • 54 Answers
Check with medicine chamber for leakage and breakage
Posted on Jul 29, 2011
Runs for a few minutes then stops
Forget the visually appealing white mist humidifiers that leave you with a white slime to clean up. Get yourself a warm mist humidifier without the hassle, works better and no mess to clean up!
Jan 22, 2013 | Air-O-Swiss 7133 Humidifier
No medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
May 31, 2010 | Respironics HS800 Disposable Nebulizer Kit...
Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Feb 09, 2010 | Vicks Humidifiers
HUMIDIFIER IS VERY NOISY AND MIST SPRAYS FROM ONE SIDE ONLY
You should have bought a Cleanaer! It's totally silent, reaches all corners of the room with its patented LiquidIon technology not only takes the bad particles from the air, but locks them out for good so they do not reenter the airspace when you cross the room or disturb the furnishings.
Feb 15, 2009 | Bionaire Humidifiers
My bionaire CM1 makes bubbling sound every other minute
Yes, mine does that too. It got very annoying and I couldn't sleep. I noticed some calcification inside and gave it a rinse. I don't have the manual on cleaning it but after I did that it's much quieter. I think you should try cleaning it.
Dec 16, 2008 | Bionaire CM1 Humidifier
Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Dec 31, 2007 | Sunbeam Ultrasonic 81696 Humidifier
Mabis NebXP Portable Handheld Compressor Logo
430 people viewed this question
Top Mabis Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Dan Webster
Dan Webster
Are you a Mabis Health and Beauty Expert? Answer questions, earn points and help others
