Question about Delta Saws
Took off grinder wheels, and put them back on , now can not remove them and motor doesn't move them either
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: older black & decker bench grinder
Usually a new wire wheel comes with different size bushing just for the problem you are describing. Either that or take it back and get one specifically for your tool.
Posted on Feb 01, 2009
  • 342 Answers
SOURCE: is not charging put on new battery run it down in
check the alternator output straight from the coils usually around 18 volts ac if this is good may be down to the charge regulator / rectifier
Posted on Apr 16, 2010
No steam pressure help
see this causess and proceed .God bless you
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Lello 45920 Ariete Cafe Roma Deluxe...
Krups grinder 223
what problem do you have?
Sep 25, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder mod 233
see this causes and proceed .God bless you
Ids77 electric coffee grinder I want replace fuse how can I open this prodact please.
see this causes and proceed:God bless you
Sep 25, 2012 | Coffee Makers & Espresso Machines
How do remove the wheel from dewalt dw302 grinder
on the top side of grinder there should be a button that you press to lock the motor so you can put a wrench on it to remove the wheel...
Jan 22, 2011 | Garden
My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Jan 30, 2010 | Cuisinart (CCCCUISINART) Grinder
It always grinds very fine. I am unable to change the coarseness of the grin.
That one is hard to explain but I will try. On the front of the grinder is the adjustment wheel, on the wheel is a small screw, if you put your hand on the wheel it might be about 1/4 inch from the front, back up screw about 1/2 turn or more then make sure the grinder is on 3 or espresso, make sure you can pull out front part of the wheel ONLY. If not back up screw a little more and try again, now that it can move freely without moving the numbers, pull it out and turn it to about 5 or 6 then turn grinder on and very SLOWLY, (This is the dangerous part do not go to fast or you could damage the grinder) turn towards trukish grind when you get close you will hear the burrs slightly touching. Back off the knob a little just before the touching part and turn grinder off. Then pull knob out and turn it to turkish and set screw.
Nov 10, 2009 | Bunn -o-Matic G3 (3 lb. Commercial Coffee...
Older black & decker bench grinder
Jan 31, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Saws Logo
27 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
