Question about Nokia N95 Cellular Phone
I want to format PHONE MEMORY of my NOKIA N95 8GB? I am unable to delete applications in phone memory. Is there any way to format the phone memory?
    Problem Solver:
  • 6 Answers
Switch off ur mobile and whn turning on hold three key of phone (call key, # ,end key OR call key, #, 3) dnt release keys until phone fully starts. Aftr u will get ur phone is formatted. Plz backup ur contacts and other data befor doing this in memory card or pc and then restore. swapnilbhujbal@live.com
Posted on Apr 10, 2011
I wan to format my n79 phone
There are three ways you can format your Nokia N79
  1. To only remove settings and leave your applications and user data intact.
    Dial *#7780#
  2. To delete contacts, messages, calendar events, applications installed to the phone's memory and all settings. Please note that you will need to format your memory using a computer to make sure that everything is deleted.
    Dial *#7370#
  3. Bring it to Nokia Service Center to have it re-flash or reprogram.
Feb 15, 2011 | Nokia N79 Cellular Phone
Memory low unable to delete applications @gmail.com
you can do only one thing please format the phone using this code
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
your problem will solved.
Oct 23, 2010 | Nokia 6630 Cellular Phone
How to format nokia 3310
*(asterisk) #(number sign) 0(zero) 6(six) #(number sign)
The CODES:
*#06# - displays the unique serial number or IMEI number
*#0000# - shows the firmware or software version details
*#2820# - Bluetooth (BT) device address
press and hold the ZERO (0) button - brings you to the homepage of your wap/gprs
press and hold the MENU button - launch the phone's task manager. you can then switch between active programs or terminate a running application by press the CANCEL/DELETE (c) button.
*#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up).
*#7370925538# - reprograms your phone's wallet application. all information on your wallet will be erased and the wallet code will be removed.
Apr 16, 2010 | Nokia 3310 Cellular Phone
I can't format my nokia 3110c phone memory
i want to nokia 3110 c phone memory format code Please give me sugg.
Mar 26, 2009 | Nokia 3110 Cellular Phone
N81 Format
when formating your phone, the default settings, pictures and other application will be restored, but other application like ultra mp3, or cam coder surely it will be deleted unless it is installed on your memory card cause the only thing that will be formatted is your phone memory,
Jan 01, 2009 | Nokia N72 Cellular Phone
Unable to delete
you need to format the memory where the file you want to delete is located.. exp: MMC
or format the whole phone by using this code: *#7370# the O.K then enter your sec. code.. (the default code is 12345)
if the file you want to delete is still there, then after phone format for mat your MMC or external Memory..
Aug 29, 2008 | Nokia N72 Cellular Phone
Problem after formatting the phone
Not enough memory, means your phone is too full of data IE. Pics, Themes, Contacts, Applications, Games, Old Bluetooth files, etc...
The phone needs a certain amount of memory to function.
If you fill the memory to the brim, your phone won't work. go into the File manager to delete some of the old files or/and into the Application manager and delete some unused applications.
I know it's too late this time, but if you use Nokia PC Suite, you can backup your phone, and in the eventuality that you reset your phone, you can restore your files.
I think you'll have to reload your songs the hard way.
Apr 01, 2008 | Nokia N70 Cellular Phone
Formatting
for formatting the handset,you can dial *#7780#....than it will ask the security code you have to give the default code as 12345 or you you can give your personal code which you have given…this will not delete any data from your handset…other way is to do the hard reset that will delete all the data for that youi have to dial *#7370# again it will ask the security code similarly you have to given ealier
Apr 26, 2007 | Nokia 6600
Nokia N95 Cellular Phone Logo
117 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
