Question about Simplicity Fashion Pro SW2145 Mechanical Sewing Machine
Need Instructions for Simplicity Modle 1700 Manual Sewing Machine
I need the insturctions for a manual simplicity sewing machine modle # 1700. It's different from any other manual sewing machine that I have owned, so need help. Thank You, Janis
SOURCE: A MANUEL FOR A SIMPLICITY SEWING MACHINE MODEL 237
To find the manual online goto simplicityhomecare.com. Under the PRODUCTS tab you'll see Instruction Manuals. Click on that and you'll have a choice of what machine you need an instruction manual for. Look under the Sewing Machine and you'll see the SL237 - Denim Expert. Hope this helps!!
Posted on May 01, 2008
talk2ginny
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
  • 76 Answers
SOURCE: threading instruction for model #1220 simplicity
http://www.sewingstyle.com/Simplicity-Sewing-Manuals.htmlnot
not sure if you have the manual, try this site for a manual,
Posted on Sep 03, 2009
  • 22 Answers
SOURCE: I am looking for the power cord for the Simplicity
Try this online dealer:
http://www.sewingmachinesplus.com
Posted on Nov 10, 2009
jyackle5
  • 8197 Answers
SOURCE: Need To know wher I
You can get the manual on the link below. scrool down to product details then click on the product manual.
http://www.amazon.com/Simplicity-SA2200-Creative-45-Stitch-Function/dp/B0000648AG
Good luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 17, 2010
How to oil a simplicity serger SL370?
The owner's manual is the best resource for oiling instructions. After that, probably a sewing repair shop.
Instruction Manual Simplicity SL370
Different machines require different oiling. As a serger, it most likely requires more frequent oiling than a sewing machine, so it is important that it be cleaned and regularly.
May 31, 2016 | Simplicity Sewing Machines
Need an operating manual for Simplicity, Model SW210
Sorry Angela, been looking for a manual for my Simplicity too but can't locate one either. If we don't contact manufacture for one, we may not get one. Unless someone out there has one to scan and share? Come on folks, help out!
Nov 18, 2011 | Simplicity Denim Star SW210
I need help
If you just need the manual, you can download it here:
Simplicity manual
Dec 08, 2008 | Simplicity Serge Pro SW432 Mechanical...
Simplicity Fashion Pro SW2145 Mechanical Sewing Machine Logo
65 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
